Results 121 to 135 of 530
07-10-2018, 06:01 PM #121Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
That's just beautiful man.....So many mercs....Like soldiers waiting to go to war.
07-10-2018, 06:34 PM #122
Randy your motor looks unreal cant wait to hear how it runs!
07-10-2018, 06:40 PM #123
I put it on a new red Liberator today. Just gotta wait for the "CLEAN POWER" harness and rigging tube. It's a cable shift motor, but what's cool is that the cables only operate an electrical swith. They don't mecanically shift or move the throttle. That's done by solinoids (I think) It's like new cars.
Boat Delivery available
Things owned. NOTHING!!
07-10-2018, 07:46 PM #124
Hey Randy, some height/length dimensions would be appreciated. I plan on installing these on my F26 once the 1.62 lowers come out and am curious how much taller, if any, they will be. They definitely look taller and pretty badass, hopefully run even better.
Thanks.
07-10-2018, 07:47 PM #1255000 RPM
- Jan 2017
- Albany NY
- 398
- 28
- 20
- 98
- 125
looks awesome Wildman. cant wait to hear some results
07-10-2018, 08:30 PM #126
What prop are you considering?
Kirk
07-10-2018, 11:13 PM #127
Randy , do they use the hydraulic steering like the verado on these V8 s ?
thanks
bor
07-11-2018, 07:45 AM #128
The 300R uses the same type of external steering setup the 300XS uses, either Seastar Pro or Uflex. Only the V8’s with the “advanced” midsection use the integrated Verado style ram and none of those are Mercury Racing versions so they don’t have the SM lower option. They are actually called the Verado 300 and 250. All the other 4 strokes use a traditional midsection that uses the traditional aftermarket steering.
The 300R HD is also offered with an integrated tie bar wing plate but I don’t have details. Others here probably have more details on that option.Mark
bor thanked for this post
07-11-2018, 08:09 AM #129Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
07-11-2018, 09:35 AM #130
The whole reason they still can use Seastar is to make it easier for people to change over to the new motors.
07-11-2018, 09:44 AM #1316000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
I suspected that to be the case. I think merc missed out on a lot of repower business with the verado because of the expensive total rerig. I think the Yamaha sho continued to accept conventional controls. That was definitely a factor when I repowered.
07-11-2018, 09:47 AM #132
Thats a matter of opinion.
Mercury has done a real good job of tamping down one of the major flaws of their Verado power steering on single engine application which is massively magnified on surfacing applications. Basically the helm is not up to the task of maintaining pressure on the loaded side of the ram combined with their use of basic motor oil instead of real hydraulic oil means the oil and pump overheat and fluid bleeds past the valves in the helm and you get a lot of noise and constantly have to steer left to go straight. In some situations it actually becomes dangerous as the bleed over will cause the motor to pivot without input in the loaded direction. Not something You want to happen at 100+ mph.
Dual engine applications don’t have the problem since torque is cancelled between the LH and RH drives.
In a single engine, surfacing application I would NEVER implement the Verado solution over a Seastar Pro or a side mount aftermarket solution.
However, there is technically no reason you couldn’t use the Seastar Pro with Power Steering in front of a Verado motor but you would need to change out some fittings and Mercury might have some warranty issues.Last edited by mjw930; 07-11-2018 at 09:51 AM.
Mark
powerabout thanked for this post
07-11-2018, 09:50 AM #133
I have no dog in this race but I ride dirt bikes and when they started with the 4 strokes (Doug Henry rode a prototype 4 stroke in an all 2 stroke race I believe. Showing my age now, haha) way back when, they said it would never work. Now they are the mainstream and have more usable torque and power throughout the RPM range. They have also brought the weights down to close to the same as 2 stroke bikes.
Once the manufacturers get this dialed in it should be ok.
07-11-2018, 09:54 AM #134
lance thanked for this post
07-11-2018, 10:44 AM #1356000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
This is probably worth its own thread (sorry wildman!) and I've researched it quite a bit. The problem is that the viscosity does drop quite a bit and bypass the pump when the fluid gets hot, as you stated. I've learned how to reverse the wheel abruptly to get the internal valve to switch, which locks it in position well....but I shouldn't have to do that.
All of the hydraulic fluids I've found are lower viscosity than the 0w30 at operating temp so those won't work either. I found an excellent industrial oil that has a very good viscosity curve for the application but the anti-wear package isn't as strong as a hydraulic or motor oil. That leaves the lead case to be a 5w50 synthetic motor oil like mobil1.
New Mercury 300 Pro XS V8 vs 300R V8
By Skip 7750 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 46Last Post: 10-10-2019, 12:00 PM -
100 MPH ++ Single engine new boats for new 300R
By whipper in forum General Boating DiscussionReplies: 21Last Post: 07-12-2018, 08:14 AM -
STV RR/Euro + New 300R
By Talon 25 in forum General Boating DiscussionReplies: 13Last Post: 06-16-2018, 09:53 PM -
New! Mercury 250R and 300R
By RUM RUNNER 305 in forum General Boating DiscussionReplies: 90Last Post: 05-25-2018, 06:02 AM
