Results 421 to 435 of 530
07-28-2018, 09:02 AM #4215000 RPM
- May 2007
- STL
- 856
- 14
- 15
- 48
- 25
07-28-2018, 09:05 AM #422Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Get a herring on that thang......Might be faster than the merc by a few. It likes big dia. 5 blade wheels.
07-28-2018, 09:15 AM #423Member
- Jul 2018
- LOTO
- 41
- 22
- 31
07-28-2018, 09:25 AM #424
07-28-2018, 09:42 AM #425
07-28-2018, 09:55 AM #426
It could be small but the other 14.5’s they’ve tried are overhub so they are getting too much ventilation. I’m not saying it would be the fastest but if it can stay hooked up and come in under 10% slip it’s a very cost effective option. No one is going to have only one prop if you’re serious about go fast boats but it’s good to have a reliable, easy to drive everyday prop that won’t break the bank and perform well in the 60-80 mph range where you run 95% of the time.
Mark
engineermike liked this post
07-28-2018, 10:19 AM #4276000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
I agree, mark. Pro max has exaggerated progressive rake that I think improves grip. It was my best performing 4 blade on the hdsm.
07-28-2018, 10:42 AM #428Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
When you have a TON of tq, you want it hooked solid up with small slip #'s. Herring might be the ticket from the info referenced above.
07-28-2018, 12:25 PM #429
07-28-2018, 12:28 PM #430Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,645
- 606
- 923
- 1699
- 7152
- 3 Post(s)
I am more convinced then ever that the new cases are needing a 5 blade with a min. of 15" dia. and most likely a 15.250. The merc. cnc that we ran yesterday is a 34 X 15.250 with 15 degrees of rake. I hope there is a chance that I am wrong as just spent a bunch of money with Jim Herring having a set of 37 X 15 four blade over hubs made-if not they will work on the 3L cases. Jim is also building me a set of 15 X 35 five blade overhubs with a 14 degree rake and Dave DeWald is building a set of 35 X 15.25 5 blade overhubs with 12 degrees of rake. With all of these in hand, we should have enough to get a pretty good base line on the DW28 with 300Rs-now imagine another 75 hp and another 400 rpm added into the picture
The motor took the 21 liberator to 6300 with 20 lbs. of water pressure. I think that with perfect water and bringing the motor up another 1/16th to 1/8th of an inch we can pull a 107 or 108 pass out of it this particular boat. We are at 9 percent slip which has been pretty typical for Randy and the 21 ones over the past 15 years.
On the fuel usage issue, we have used 35 gallons so far with run time of around 8 hours (the majority of this was cruising 40 to 80) waiting for the break in handcuffs to be released...my guess is that it is going to be close to what guys are used to with an XS and maybe a little more but who cares when you run swamp fuel that is available everywhere...
JoeLast edited by JPEROG; 07-28-2018 at 12:44 PM.
Greg G thanked for this postdavemvegas, kct11 liked this post
07-28-2018, 01:04 PM #431Supporting Vendor
- Jun 2008
- Maryville, Tennessee
- 1,019
- 28
- 28
- 49
- 258
Would like to seen one of these in the hands of Jon Wright on the back of a Pugh hydro with 450 hp shot of nitrous........don't ever think he wouldn't have tried some crazy chit He was going to run an all aluminum Richard Childress Chebby motor standing on end at one time. Dam I miss him. He would be eating this testing stuff up.. Good job on keeping all of us motor heads informed guys. You done good.
Dave Hensley
1986 XR2002 /12" Mariner and string steering
18' Pugh Hydro
1992 XTB-21/225 ProMax
The barn is emptying out!!!
07-28-2018, 03:23 PM #432Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
07-28-2018, 06:01 PM #433
If I’m not mistaken you have only run one thru hub which happened to be a 5 blade, there are a bunch of high performance thru hub 4 blades that need to be tried before you can form a solid conclusion IMHO. I know I have a Pro ET and an identical ProMax and although the Pro ET runs great, the ProMax pulls harder in the midrange and runs a better slip number across the board. It’s probably as close as you can get to comparing overhub vs. thru hub. Then again my boat hated the Drag 4 and wasn’t fond of the blaster either so it’s obvious it runs different than a Liberator.
Mark
07-28-2018, 06:25 PM #434Supporting Member
- Apr 2003
- 6,645
- 606
- 923
- 1699
- 7152
- 3 Post(s)
You are mistaken, we tried several thru hub 4 blades (b-blades, hering, hydromotive of mine and Randy's merc. propellers). It took all of them to 6400 and slip numbers were all high. Grant has played with tons of stuff looking for a less expensive option that will last on the 400R and they either slip or throw a blade (not sure if its in the power delivery harmonics of just the 6 cylinder or if these might do the same). I think every boat will be different but the consensus on the twin engine cats is that it takes Hering, Merc. or Dewald 5 blade overhubs to please the 5.44 case.
Also remember that Brent had one of the first 400R motors and put it on his LCB. We tried everything that worked with the 3L case and none of it performed on that boat. Unfortunately, his frustration took a drivers seat on that rig and he pulled the 400 and went back to his X. It will be interesting to see how Errol and Troy end up now that we have the torque on hand with the 300R and better propeller options then what Brent was able to come up with at the time.
JoeLast edited by JPEROG; 07-28-2018 at 06:39 PM.
mach351 liked this post
07-28-2018, 07:09 PM #435
What are the props of choice for the XCats?
New Mercury 300 Pro XS V8 vs 300R V8
By Skip 7750 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 46Last Post: 10-10-2019, 12:00 PM -
100 MPH ++ Single engine new boats for new 300R
By whipper in forum General Boating DiscussionReplies: 21Last Post: 07-12-2018, 08:14 AM -
STV RR/Euro + New 300R
By Talon 25 in forum General Boating DiscussionReplies: 13Last Post: 06-16-2018, 09:53 PM -
New! Mercury 250R and 300R
By RUM RUNNER 305 in forum General Boating DiscussionReplies: 90Last Post: 05-25-2018, 06:02 AM
