Results 286 to 300 of 530
07-20-2018, 01:17 PM #286Junior Member
- Jan 2014
- AL
- 25
The bass boat guys are having to go down at least 1 prop pitch when switching from the 250 Pro XS 2 stroke to the new 250 Pro XS 4 stroke...TM lower unit on both motors but 200 more RPM with the new V8...Seems odd to me since the new V8 has more torque...? From what I can gather top end appears to be about the same with both motors.
07-20-2018, 01:21 PM #287
We were talking, and I think the reason that all the standard over the hub 14 - 14.5" props would not hook up (even at 90 mph) is the extra exhaust over the blades. While the 2.6 litre 400R works with standard props and the 300R doesn't may be because the bigger 4.6 puts out almost twice the volume of exhaust over the 2.6. All this extra exhause over the blade won't let the props hook up. The through hun Max 5 had no problem. We even ran a 36" four blade and it hit the 6400 limiter at 90. Like I said, we are just gonna need to figuer it out.
Boat Delivery available
Things owned. NOTHING!!
Greg G thanked for this post
07-20-2018, 01:26 PM #2886000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
07-20-2018, 01:48 PM #289
07-20-2018, 01:51 PM #2905000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Maybe someone has to come out with a mod to make more of the exhaust come out of the mid. Time will tell
07-20-2018, 01:57 PM #291
I tried to talk Wildman into short Zoomie headers even brought hole saw, He would not let me get close to cowling.
24 Twister
07-20-2018, 03:02 PM #292
Thanks Randy, great info here. Really like this engine. Probably not long before they have an optional gear ratio.
07-20-2018, 03:06 PM #293
07-20-2018, 03:31 PM #294
Out of curiosity,what does one of the 5 blade wheels cost this thing seems to like. Yeah yeah I know "if ya have to ask you cant afford it"
Rob Lankford
1988 20' Action Marine 2.4 200
Previous owned boats worth mentioning
1976 17' Action Marine 2.4 200
1984 20' Action Marine 2.5 200
1983 17' Hydrostream V-King 2.4 Bridgeport
2003 LPB STV RR COPY 2.5 280 /300 Drag
2005 LPB STV RR COPY 2.5 280
2005 Baja 23 Outlaw 6.2 Mercruiser
2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
2009 FTP Quarter Shot T3 Race 2.5 280
07-20-2018, 03:35 PM #295
I would not think the amount of exhaust coming out would be more if any. That boosted motor i guarantee is shoving that exhaust out at a much higher velocity. Can't wait for some time with the new R set up sweeeet stuff!!!
2011 DCB F26
2017 300 XS DBR
Davidlake liked this post
07-20-2018, 03:39 PM #2965000 RPM
- May 2007
- STL
- 856
- 14
- 15
- 48
- 25
07-20-2018, 04:15 PM #2976000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
The cnc 5 blade cleaver is like $5k. The max5 is the best I've run and it's about $1800. The Maximus, p5x, and 5-speed are cheaper but still over a grand. In all fairness, all max5's are labbed.
As a side note, the promax was the best performing 4-blade on my boat.Last edited by engineermike; 07-20-2018 at 04:18 PM.
07-20-2018, 04:39 PM #298
engineermike liked this post
07-20-2018, 05:58 PM #299
Or another way to look at it, a NA 4 stroke motor moves 1/2 it’s displacement per revolution. A 2 stroke motor moves its displacement per revolution. A forced induction 4 stroke motor moves 1/2 it’s displacement per revolution x 2*(boost pressure / 14.7).
NA 4-stroke 4.6L = 2.3L per revolution
NA 2-stroke 3.2L = 3.2L per revolution
Supercharged 2.6L with 14.7lbs boost = 2.6L per revolution
At 7000 rpm the 400R is moving more air than the 300R at 6400 rpm but still less than the 300XS at 6200.
The power the motor creates is more than a function of air flow though better air flow does increase power since it makes the motor more efficient. Compression ratio or effective compression ratio in a boosted motor has the biggest effect on power. The higher the compression ratio the more energy is released in each power stroke. That’s highly simplified but it’s a basic rule of thumb.
So, the idea there’s more aeration on the prop is more a function of the hydrodynamics of the lower unit than airflow from the exhaust. What’s surprising is the difference in performance between the 300R and the 400R, aren’t they essentially the same lower? Could be the lighter motor is being carried higher than the 400.Last edited by mjw930; 07-20-2018 at 07:44 PM.
Mark
powerabout liked this post
07-20-2018, 07:26 PM #3005000 RPM
- May 2007
- STL
- 856
- 14
- 15
- 48
- 25
New Mercury 300 Pro XS V8 vs 300R V8
By Skip 7750 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 46Last Post: 10-10-2019, 12:00 PM -
100 MPH ++ Single engine new boats for new 300R
By whipper in forum General Boating DiscussionReplies: 21Last Post: 07-12-2018, 08:14 AM -
STV RR/Euro + New 300R
By Talon 25 in forum General Boating DiscussionReplies: 13Last Post: 06-16-2018, 09:53 PM -
New! Mercury 250R and 300R
By RUM RUNNER 305 in forum General Boating DiscussionReplies: 90Last Post: 05-25-2018, 06:02 AM
