Results 1 to 13 of 13
    May 2018
    Puerto Rico
    Mercury 2005 Saltwater Series 200 HP Carburetor Failure
    Hi guys, can some body help me on this matter, I didn't use my boat for almost a year
    so I tried to use it during this weekend and found that racor was full of water, then
    when i hit the throttle I found that the motor have no power. My guess is that the water
    that was on the racor run trough the gasoline system and damaged the carburetor or have
    water on it. Can somebody help me on this.
    Thanks...
    Sep 2017
    Ashland city tn
    Pump some fuel into a bottle and let it settle and take look at it, if it has water ,drain entire system and bowls of carbs
  3. Thanks Saulunaproline22 thanked for this post
    May 2018
    Puerto Rico
    Thanks, I'll do that. How about the sparks plugs, did I have to change it.
    Luis
    Sep 2017
    Ashland city tn
    ,,it's always good maintenance to change plugs,also when u pull them out ,look for water beads on plugs
  6. Thanks Saulunaproline22 thanked for this post
    May 2018
    Puerto Rico
    Ok, I've been using Champion spark plugs did you recommend this sparks or use the NGK?
    Luis
    Sep 2017
    Ashland city tn
    For tech tips ,make sure to post in technical discussion, you will get a lot more info over there about any problems. Welcome to scream&fly , great place for anything boating!
  9. Thanks Saulunaproline22 thanked for this post
    Sep 2017
    Ashland city tn
    I'm not familiar enough with 05 model but I'm gonna assume u need ngk. Put up a thread over on tech discussion or search the threads. Probably a faq from lots a folks
  11. Thanks Saulunaproline22 thanked for this post
  12. #8
    May 2018
    Puerto Rico
    Ok, thanks for you help!!!!
    Luis
  13. #9
    Sep 2017
    Ashland city tn
    I'm assuming your motor is a 2.5?
  14. Thanks Saulunaproline22 thanked for this post
  15. #10
    May 2018
    Puerto Rico
    Correct.
  16. #11
    Sep 2017
    Ashland city tn
    Bu8h ngk. I'll double check
  17. Thanks Saulunaproline22 thanked for this post
  18. #12
    Sep 2017
    Ashland city tn
    Do you know if it's a cdm ignition? Also there's likely a sticker on air box or flywheel cover with plug type recommended
  19. Thanks Saulunaproline22 thanked for this post
  20. #13
    May 2018
    Puerto Rico
    I'll have to look at it, I let you know.
    Luis
  1. 2015 Playcraft Daytona Saltwater Series w/Mercury 250 Pro XS
    By Carlson150XS in forum Hulls larger than 20'
    Last Post: 12-04-2017, 05:36 PM
  2. 2005 Mercury 4 Stroke 115 EXLPT EFI Saltwater
    By MERCSPEED in forum Outboard Engines
    Last Post: 10-26-2017, 12:21 PM
  3. Mercury Tech: Rebuilt 125 hp Mercury Saltwater Series Powerhead Break-In
    By rickyo in forum Technical Discussion
    Last Post: 07-09-2010, 01:54 PM
  4. Mercury EFI 150 saltwater ECU failure
    By motionbroker in forum Technical Discussion
    Last Post: 07-08-2006, 09:43 AM
