Results 16 to 30 of 88
Thread: 2.5 260 question
07-02-2018, 08:49 PM #165000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
The parts diagram I have only shows two of the fittings also and I have 3 in the horn. Shows two different party numbers also? Ones 3$ and ones 18$ they both look the same tho
07-03-2018, 03:04 PM #175000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Can anyone shed some light for me?
07-03-2018, 08:50 PM #18
If possible find a drill bit the correct size of hole (not bigger) little small if anything, if u can drill it out and make sure u have all shavings and trash out while horn is off,u can put new ones in with some blue loctite , it worked for me on carb motor ,should work for u ,but then again I've never owned a horn motor
07-03-2018, 09:13 PM #195000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
I got the piece out I went and got a punch set. Just not sure about what fitting to buy. Ones 3 times the cost wondering if ones a check valves like the top bleed fitting on the top bearing.
07-03-2018, 09:22 PM #20
As stated b4 I've never owned one but I would think 1 is check valve others are just ''fittings'' ?
07-04-2018, 12:33 AM #21
Watching this thread Bunger. I just picked up a 300 drag also. Doing the same thing to my Baker. What part of Cali are you in? Nice to see someone close on here.
Bunger liked this post
07-04-2018, 10:30 AM #225000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
07-04-2018, 02:17 PM #23
07-04-2018, 09:25 PM #245000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
07-04-2018, 09:40 PM #25
07-04-2018, 09:42 PM #265000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
07-04-2018, 09:52 PM #27
jus double check numbers with tha parts guy...
07-05-2018, 06:02 PM #285000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Is there anywhere I can find all the tourqe settings for this thing? Need info for heads, exhaust divider, horn and flywheel
07-05-2018, 07:41 PM #29
gave all my hi perf manual junk away..
fw.. think 120 lbs minimum
divider.. 17/18 lbs.. Loctite 271.
head.. 35 ta 38.... debatable! never had any problems at those numbers.. lite oil
horn.. ? maybe 'bout same as divider.. maybe a tad less.. Loctite 271
jus my version of numbers...
07-08-2018, 09:53 PM #305000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Can anyone tell me what pistons these are? Snapped a pic before I put the heads back on. They say “1096 star 352”
Merc tach question,and charging question
By hydroguy21 in forum Electronics, Audio Systems, and WiringReplies: 0Last Post: 07-24-2011, 04:56 AM -
Hydrostream reintroduction question Question
By roostertailn826 in forum General Boating DiscussionReplies: 2Last Post: 09-18-2009, 01:45 PM
