Results 31 to 45 of 51
07-04-2018, 08:06 PM #31Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
07-04-2018, 08:10 PM #325000 RPM
- Nov 2004
- 140
No air box, that is the only pending test that I will expect to do this Saturday.
07-05-2018, 12:01 AM #33Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
07-05-2018, 05:03 AM #345000 RPM
- Nov 2004
- 140
Already check that and they are for an 86 3.6 gt.
07-05-2018, 05:25 PM #35Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
86 3.6 has 80D stock jets the 78D were in 1985 which had a different smaller carb
07-10-2018, 12:56 PM #365000 RPM
- Nov 2004
- 140
The power packs cables were disconnected and the issue remains the same. Any other suggestion will be considered.
07-10-2018, 07:25 PM #37Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
You will need main jets over 80 if you run it without an airbox, do you have the baffle and airbox to put on for a test?
Have you marked the flywheel to check timing on all 8?
buy a dva adapter for your multimeter and check the coil primary voltages
Did 4 cyl keep running when you tried to stop it with the pack loom unplugged where the shift loom should go?Last edited by powerabout; 07-10-2018 at 07:29 PM.
07-11-2018, 06:13 AM #38Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
86 3.6 did not have a baffle in box but came with 80D mains
07-11-2018, 08:10 AM #39Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
07-11-2018, 05:56 PM #405000 RPM
- Nov 2004
- 140
The jets are 76d and the engine does not have the air box. The loom was disconnected and the engine do not turn off. I am planing to install higher jets but I do not find a biger ones. I will drill them, or maybe any of you can point a store that sell me a new set.
07-11-2018, 06:34 PM #41
Carb throats cracked?
Azure AZ259, 8.1
07-11-2018, 06:59 PM #42Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
You will still need to get the diode into the loom between the packs regardless of anything else.
Its can cause issues in all rev ranges
Time for voltage check on coil primaries to see if it drops away, make sure that the pack kills wires are separated when you do thisLast edited by powerabout; 07-12-2018 at 03:12 AM.
07-11-2018, 07:31 PM #435000 RPM
- Nov 2004
- 140
Carbs were inspected and all 8 are in good condition with new kits.
07-12-2018, 06:34 AM #44Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Get the proper jets in it first before you hurt the engine. 4 sizes below stock is enough to cause running issues. Jets should be available from any dealer, I may have some but need to check.
07-12-2018, 09:55 AM #45Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Mercury Tech: Fuel Delivery Issues...XR2
By Sonik in forum Technical DiscussionReplies: 19Last Post: 08-22-2010, 10:03 PM -
Fuel Delivery Issues....
By HavasuDreamin' in forum Technical DiscussionReplies: 0Last Post: 06-01-2009, 09:10 AM -
By HavasuDreamin' in forum Technical DiscussionReplies: 3Last Post: 06-09-2008, 05:54 PM -
2.5 Fuel Delivery
By gtsmpuc in forum Technical DiscussionReplies: 4Last Post: 09-25-2001, 09:55 AM
