Results 1 to 6 of 6
06-24-2018, 03:20 PM #1
has Hydrostream ever built Vegas XT with no core?
https://www.screamandfly.com/showthr...500wbd06032018
I have a 1985 Hydrostream Vegas XT. I removed a screw (pic below) with a plastic wire wrap from the hull bottom. the screw was punched through in the notch area of the hull bottom
when I removed the screw, it was no more than 1/8+ inch thick and from the inside of the boat I can just barely see the tip of the screw.
So I ask has Hydrostream ever built the Vegas XT in 1985 without any core or maybe an owner before me removed the core?
Here is the screw, with the plastic wire carrier, and whilst the screw was in the hull, I can barely see the tip of the screw from inside the boat
when I removed the screw and measured it, this is what I got
06-24-2018, 03:22 PM #2
06-24-2018, 03:26 PM #3
if there is a core in the hull, how thick is the balsa core?
06-24-2018, 06:32 PM #4
I also measured the thickness of the rounded-tunnel hull bottom and the thickness is also 1/8+ inch
06-24-2018, 07:07 PM #5
Where in the hull was this screw? Pretty sure they aren't a full core boat. You mentioned the notch area, I know my Hydrostream isn't cored in that area. The XT should have a cored pad and tunnel contours, but pretty sure that's it.
noli liked this post
06-24-2018, 07:18 PM #6
This is great news, thanks!
hydrostream hst core
By Gassman109 in forum Technical DiscussionReplies: 2Last Post: 12-07-2016, 08:21 AM -
Who built a Go Fast Center Console without core materials?
By Stitch King in forum Fiberglass and Composites DiscussionReplies: 19Last Post: 10-06-2013, 09:51 AM -
TOTAL RANT!!!!! WTF is happening to the Core of What built this
By HStream1 in forum The Scream And Fly LoungeReplies: 24Last Post: 12-06-2012, 08:46 PM -
Hydrostream re-core help
By FusionFab in forum Fiberglass and Composites DiscussionReplies: 10Last Post: 04-06-2012, 01:34 AM -
new core in the hydrostream
By cuffer22 in forum Fiberglass and Composites DiscussionReplies: 16Last Post: 03-07-2008, 06:02 PM
