Results 1 to 2 of 2
    Jun 2018
    Lincolnton ga
    98 mercury 200efi
    Hey guys thanks for the add to the page. I need some help i have a 98 mercury 200 efi it has been sitting for 3 years it has sat for two years before it was ran last time this time i took it back out the shop i put new gas new filter changed the plugs checked the compression a new battery i cleaned the injectors i checked pump pressure on both sides of regulator I'm getting 35 to 40 psi it reeves up fine it idles but when i put it in gear and give it gas it when i hit the pedal it acts like it runs out of fuel and cuts off any ideas ?
    Jun 2018
    Winona MN
    Mercury XRI manual
    I would make sure to check the throttle position (TPS) setting, and ignition timing. If spark timing is off, it may run okay when it is not in gear, but once you put it under load it can be an issue. Follow the Timing and synchronization for EFI models procedure in this manual. Good luckClick image for larger version.
Name:	Mercury 200XRI manual.pdf
ID:	411858 (that black blob is the manual pdf)
  1. 1999 Mercury 200efi
    By 99jav in forum Outboard Engines
    Last Post: 02-13-2018, 10:08 AM
  2. Mercury Tech: Mercury 200EFI 2.5 CDM's or Coils - whats better?
    By 1800Bullet in forum Technical Discussion
    Last Post: 09-02-2014, 05:41 AM
  3. Mercury Tech: Mercury 200EFI Modifications
    By Jono69 in forum Technical Discussion
    Last Post: 08-10-2011, 07:46 PM
  4. Mercury Tech: mercury 200efi 2.5l 1998 oil injection removal
    By jhwh in forum Technical Discussion
    Last Post: 07-09-2010, 06:32 PM
