Results 1 to 15 of 25
    new york babylon
    V-8 lower formula race lower?
    What is it looks like vV-8 factory low water pick up lower has cr. Stamped in sideClick image for larger version.
ID:	410709Click image for larger version.
ID:	410710Click image for larger version.
ID:	410711Click image for larger version.
  2. Likes afr liked this post
    Jul 2004
    Galveston TX
    sent you a pm.
    Shawn B.
    Calgary, Alberta
    Housing looks exactly like my Second Effort V6 case.
    Matt
    new york babylon
    Yeah thanks want sure till someone told me
    Aug 2010
    Barrie, Ontario, Canada
    That gearcase would most likely only work on a 1985-1987 3.6 counter rotation engine because the counter rotation powerhead actually spun counterclockwise. I had a CR and SR case. Those cases were slow but bulletproof.
    Triad V21 #002 - 15in DBR 300 xs
    19' J-Craft - 175 Opti
    18' Pontoon - 115 CT 4S
  7. Likes Capt.Insane-o liked this post
    new york babylon
    Thanks. For IMF
    8 Post(s)
    Quote Originally Posted by V-bottom View Post
    Very nice, what were they on?
    They are also a different shape than the first one posted?
    Aug 2010
    Previous boat. Had it from '1992 - 2011
    Attached Thumbnails Attached Thumbnails trial n error 005.jpg   motor pictures - 300 005.jpg
  11. Likes Instigator liked this post
    7 Post(s)
    I loved that boat.
    Aluminum deck.
    i remember it coming up for sale and wishing my timing was better.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  13. Thanks V-bottom thanked for this post
    Jun 2017
    idaho
    Gear case
    Can you tell me why this gear case would be slow? Do they have different gear ratio. I have the same case on a 4.0 liter v8 and I'm struggling. Any help would be appreciated.
    Dec 2001
    What boat motor and How slow..?
  16. #12
    Aug 2010
    Quote Originally Posted by idahoavenger View Post
    As said by Dave S what speed do you consider slow? What type or weight is your hull?
    Jun 2017
    idaho
    Gear case
    I have a 1991 gt300 v8 on a 21 foot avenger modified tunnel. It weighs about 1500 less the motor. I'm having a hard time getting it much over 60. It will turn 6000 with four blade 25 but only running 61 on the GPS. I tried 4 blade 28 but it won't turn that more than 5200 at 52 mph. It should be running better than that. Compression is 120 to 125 in all cylinders.
  18. #14
    Dec 2001
    Trim button.... just kidding....# don't add up....something is wrong.
  19. #15
    Jun 2017
    idaho
    gear case
    Yeah doesn't add up. Someone said something about the gear case being slow. My gear case looks just like the one in the picture above.
  1. Mercury Tech: Question on Mercury Lower Units: 80' 2.4 200 lower swap to 2001 opti lower
    By NoRdO in forum Technical Discussion
    Last Post: 08-16-2016, 09:21 PM
  2. Race Lower
    By SANTAFE in forum Parts Wanted
    Last Post: 01-10-2016, 01:35 PM
