Results 1 to 8 of 8
Thread: Ran motor with 1 dry carb.....
06-21-2018, 09:21 PM #17000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Ok. I cleaned the carbs on my 3.0 johnson. After starting I it up I noticed one bowl didn't have any fuel spray coming up from the bowl. So I shut it off and took that carb off. Was a stuck float so the bowl was dry. I took the plug and l looked inside as best I could. Everything looked a little oily. Should I be really concerned about damage from running it for a couple min with no fuel?
06-22-2018, 05:33 AM #2
Was it just idling on hose? Probably didn't do any or much damage. Run a compression test and see what that says.
06-22-2018, 06:04 AM #3Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
If no fuel made it to the cyl , nothing to ignite . Not the same as running at speed and leaning out to just enough fuel to do damage .
06-22-2018, 07:29 AM #4Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
no fuel, no oil but you get some from the cylinders above plus what was already there.
They will idle for hours with no oil, tested that at a service school
06-22-2018, 08:10 AM #5Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Sure but not enough to fire it, won't run 1 second without fuel. About the same as disconnecting the fuel line and waiting for it to run out at idle, I don't do that but ...
06-22-2018, 01:07 PM #6
Not enough fuel to create any heat. As long as it had enough lube to not score the cylinder you will be fine.
06-22-2018, 06:00 PM #7
It will be fine as long as you weren't reving the crap out of it.. the oil in the gas only replenishes the built up oil in the engine as it makes its way thru and finally out the exhaust .Dave
06-22-2018, 06:07 PM #87000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Cool, I didn't run it long and didn't rev it too much. And was bone dry not lean. Just on the hose.
2.4 Horn Motor/2.5 Carb Motor
By ttopping in forum Technical DiscussionReplies: 1Last Post: 10-29-2014, 09:34 PM -
Bought 1997 Merc OS Carb 225 3.0, and parts motor EFI..Can I use efi on carb engine
By Zoomba in forum Technical DiscussionReplies: 2Last Post: 02-19-2012, 08:59 AM -
250 efi fit on a 225 carb motor?
By cjg454ss in forum Technical DiscussionReplies: 7Last Post: 10-14-2010, 05:55 PM -
3.0 carb motor?
By jimmyz32 in forum Technical DiscussionReplies: 0Last Post: 04-22-2007, 06:18 PM -
Converting a 91 chevy truck to Hot Rod Motor carb motor need advise !
By Jay Smith in forum General Boating DiscussionReplies: 20Last Post: 11-29-2001, 10:45 PM
