Results 1 to 10 of 10
    Mar 2009
    Maine
    Blew up my 2.4 Land an Sea 1987 motor
    My freshly re ringed 2.4 ran great for 30 hrs and then blew up. I had it propped for 6300.
    has a spacer plate and high ports 145 psi heads. About 34cc
    had good water pressure and didn’t overheat.
    .82 jets, so fat jetting
    ran super strong, was pushing my 21 Sanger to a very punchy 60
    bottom cylinder blew
    there was a bit of water in the bottom cylinder.
    anyone got any ideas? Head looks awfully clean.
    Bottom crank seal?
    ****ty Marina fuel?
    too much compression?
    needs a sleeve.
    dave
    Attached Thumbnails Attached Thumbnails 458B2F0B-FCDD-4195-A50D-0740E0EA2C0B.png
    Sep 2015
    Twin Cities, Minnesota
    Those don't look like Land and Sea Heads at all.
    I lost the same cylinder a few yrs back. Not sure why. I was just putzing along at 60mph too. My mains jets were 98.5's in a set of WH22's with 26cc heads and 4 pedal sport jet reeds.
    Mar 2010
    houston, tx
    Quote Originally Posted by Krazymaan View Post
    land and sea had a lot of different levels on their performance builds, not all of them had the heads like yours
    Mar 2009
    Maine
    Quote Originally Posted by 90 5.0 View Post
    the Land and sea part of my motor is pretty much the connecting rods and block. I was told this by the previous owner. They also machined and ported the block and rechromed
    Supposedly. I acquired just the block and pistons crank rods etc in a trade.
    so I could be wrong. But the connecting rod bolts are allen bolts. And the pistons are d ported. Well. Except the melted one.
    What modle carbs and timming?
    Shreveport, La.
    can I change my user name or do I have to make a new account/register again? I didn't know about the original Phil, Out of respect I probably should change it even though spelling is different it's still the same name.
    Those heads are great for making hot water.
  7. Likes Capt.Insane-o liked this post
    Sep 2015
    Quote Originally Posted by Da Bull View Post
    That's exactly why Ruck modified them. He knew what he was doing. Besides,they all make hot water.
  9. #8
    Jul 2012
    Lufkin, Texas
    They made a dual plug version of that head too. The only set I’ve ever seen had one hole peppered real bad...
    Josh Peterson
  10. #9
    Sep 2015
    You can sleeve just 1 cylinder but It will be steel. You can the chrome but it will be Nic, not chrome. But they can only do all 6. Not just 1. It's nice to hear that a few land and sea parts made it all the way to 2018. I hope you post some pics of the parts, I'd be curious to see the items.
  11. #10
    Mar 2009
    Maine
    Quote Originally Posted by roadkill636 View Post
    Wh 31 80 .82 jets, 145 150 psi, cut 2.0 heads . 152 ports, cut exhaust chest. 23 timng
  1. land n sea jack motor
    By SUPERSTOKER in forum Technical Discussion
    Last Post: 04-21-2013, 03:20 PM
  2. Rut Ro - Motor Blew Up - Need Advice
    By Port Monster in forum Technical Discussion
    Last Post: 06-03-2011, 12:51 PM
  3. what motor will fit in a 1987 glassport
    By jonboy in forum Technical Discussion
    Last Post: 08-15-2009, 11:36 PM
  4. need oil mixture for a 1987 120HP v4 motor
    By judsonboatman in forum Technical Discussion
    Last Post: 12-12-2004, 05:07 PM
