Results 1 to 7 of 7
    Nov 2016
    Geneva, Florida
    Mercury 200 Case question
    Is there a way to tell if a Mercury 200 case is a big bearing or small bearing case without taking it apart? I heard that id it has the zincs over the cavitation plate the it's a small bearing case and if it has the vents instead if zincs, it's a big bearing case. Is this true? any help would be appreciated.
    Jan 2008
    eatonton ga
    It’s in the casting number but can’t remember what to look for
    19 bullet
    82 v king
    84 v king
    93 stv pro comp
    07 venom
    80 gt20
    93 v-21
    89 stv procomp
    97 xr 2001
    89 stv pro comp
    82 17 action marine
    99 action craft flats boat
    88 xr2002
    90 Stv pro comp
    10 mirage 1/4 master
    98 mirage 1/4master
    charlotte,nc
    Casting #s for big bearing
    1647-9147 C
    1647-9147 C1
    death is certain; life is not
    Nov 2016
    Geneva, Florida
    Quote Originally Posted by nelson edens View Post
    1647-9147 C
    1647-9147 C1
    where do you find the number?
    Sep 2017
    Ashland city tn
    Around the exhaust exit in top of the lower ,
    Big bearing ratchet case, small bearing non ratcheting.
  7. Likes bullet123 liked this post
    Dec 2011
    Ottawa
    Ya C or C1, all cases with anodes are 96 up and non ratcheting.you can also use the 3l bearing carrier with a small mod to the keyway in the C/C1 case
  1. Mercury 2.0 / 2.4 / 2.5 4 Hole CLE Gear Case (Case Only)
    By Pachanga_rick in forum Lower Units
    Last Post: 04-02-2018, 01:48 PM
  2. 3.0 gear case question
    By TEXAS20225 in forum Technical Discussion
    Last Post: 06-24-2013, 09:55 PM
  3. Mercury Tech: Mercury Quicksilver A/B gear case question
    By ZUL8TR in forum Technical Discussion
    Last Post: 06-04-2010, 08:57 AM
  4. Propeller Question Alpha Case size to Stock 200 Case
    By WOT RACING in forum Technical Discussion
    Last Post: 07-08-2009, 08:05 PM
  5. 2.5 Gear Case Question
    By Maritime_Eng in forum Technical Discussion
    Last Post: 08-28-2008, 05:48 PM
