Results 1 to 6 of 6
06-15-2018, 01:00 PM #1Junior Member
- Feb 2012
- Raceland Louisiana
- 14
which would be stronger and faster
2005 225xs vs 1998 2.5 200 efi with 18787c-4 heads, bobs tuner, 16 amp flywheel and brucato set at 7500 rpms ?
06-15-2018, 01:06 PM #2
I would prefer the 200. Setup would probably make the biggest difference between the two in top end but the older motor will probably punch harder! The 225xs is probably better mannered and more fuel efficient. For the same price I would probably want to compare leak down #’s before making a choice.
Josh Peterson
06-15-2018, 01:58 PM #3
On what boat?
the heavier the boat the xs will start to be better, and the lighter the boat the modded 200 will scream
06-16-2018, 07:27 AM #4Junior Member
- Feb 2012
- 14
20' rocket hull
90 5.0 liked this post
06-16-2018, 09:53 AM #5
06-21-2018, 12:02 PM #67000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
look for am low hour 2.5xs. built in 2004-6. in stock form on a svt SnF clocked 104 with 4 people on board. i have the 200xs version and its faster than stock 200 and more fuel efficient. i have seen 80 on a HS voyager and can get 7.4 mpg at 40 mpg.
What is stronger for surfacing
By neveredge in forum Technical DiscussionReplies: 7Last Post: 06-25-2013, 12:17 AM -
Safer ?....Stronger..?...Need opinions...(pic)
By WATERWINGS in forum Technical DiscussionReplies: 17Last Post: 11-15-2012, 02:42 AM -
Mercury Tech: bravo 3 , who makes a stronger/better upper
By GDM in forum Technical DiscussionReplies: 2Last Post: 04-21-2009, 11:22 PM -
Stronger Eyesight?
By INXS in forum The Scream And Fly LoungeReplies: 20Last Post: 11-11-2004, 08:55 AM
