Results 1 to 7 of 7
    Jul 2002
    LANSING, MI
    Mercury 2.5 260-280-300 Drag Horn ECU Bracket 7 Pedal Reed Plate Parts
    Parting 1996 260 2.5 15" short shaft.. more pics to come
    Digital horn no bracket 3.5" bore (needs elbo hose fitting see pic easy fix) $170 (sold)
    Air horn throttle linkage rod $20 Click image for larger version.
    ECU bracket $55 (sold)
    bare reed plate $120
    260 7 pedal reed cages (reeds aren't chipped) 3 available $40 ea. (sold)
    7 pedal cages don't have the 0 stamped on the end little thicker point have two $25 ea.(SOLD)
    pop off valve cover $20 sold
    G-Force lightened Flywheel 6.9 lbs $500 sold
    the 15" Sportmaster & Mariner grey 15" mid it's listed under another listing
    throttle arm advance shift slide $25 each
ID:	412703Click image for larger version.
ID:	410203Click image for larger version.
    Attached Thumbnails Attached Thumbnails DSCN5331.jpg   DSCN5326.jpg   DSCN5327.jpg   DSCN5328.jpg   DSCN5329.jpg
    Apr 2017
    What's the significance of the 0 on the reed cages? I'm actually looking for (1) 7 petal cage
    Jul 2002
    LANSING, MI
    the 0 is out of the 2.5 260 280-300 the other ones are out of 225hp don't matter you can run them together, really no difference...
    Apr 2017
    Pm sent
    Dec 2011
    S.C
    I would like 2 of the 260 reed cages
    Nov 2003
    Simi Valley, SoCal
    If you still have the 260 cages I'll take all 3.
    Thanks,
    Bob
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
    Nov 2002
    St Leonard Md
    Do you still have the horn throttle linkage for sale?
