Results 1 to 13 of 13
06-05-2018, 02:53 PM #16000 RPM
- Aylesford Lake,NS Can.
- 1,728
- 34
- 152
Help!! 3.0L LH Sportmaster Carrier Seal Removal!!
I am swapping out the Mercury parts for Todd Ds billet shift shaft seals and carrier seals on my LH and RH 3.0L Sportmasters, which I have done before in other cases. I have the LH apart and discovered a different style of carrier seal than I have seen before. It doesn't have the 2 bolts holding in place and I am not sure how to remove it. There are small holes on either side but there doesn't appear to be any bolts in them. Anyone come across this style before? Take a look at the photos attached and let me know if you have seen this before and any suggestions on how to remove it. Any help would be greatly appreciated.
Thanks
Gary
06-05-2018, 02:57 PM #2
Just pops out. use leverage tool on both side
pointer liked this post
06-05-2018, 05:45 PM #3
06-05-2018, 08:21 PM #46000 RPM
- 1,728
- 34
- 152
06-05-2018, 09:12 PM #5
Yup.... grease up the o-ring, push it into place and put it all together.............
06-06-2018, 10:00 AM #66000 RPM
- 1,728
- 34
- 152
06-06-2018, 03:50 PM #7
No, the water pump does a good job of holding it in place
06-06-2018, 04:48 PM #86000 RPM
- 1,728
- 34
- 152
06-06-2018, 05:04 PM #9
Yeah if the water pump doesnt hold it in place you got issues
06-11-2018, 08:52 PM #106000 RPM
- 1,728
- 34
- 152
Okay, I just installed the new Todd D billet carrier seal and shift seal kits in both Sportmasters and I am ready to put new gear lube in. I just read another post that the LH will only hold about 16 ozs but the RH will hold 28 ozs. This is my first twin engine boat and up until now, I would put about 25 ozs in a RH with the same kits installed. I noticed when I drained the LH one there was a lot less fluid came out when compared to the RH. With the new seal kits installed, what is the correct amount of lube for each one? Also when I removed the drain and vent screws, there were no fibre washers on them even though Mercury shows them in the exploded parts view of the cases. Should I get the washers and install them or not? Any help would be greatly appreciated.
Thanks
Gary
06-11-2018, 09:54 PM #11
LH lowers require lube changes halved of the righties. I should have taken pics of the last series of lowers I've done but lefties rely on some very small thrust bearings and added internal resistance, let alone the propshafts are cut for retainers.
06-12-2018, 07:53 AM #126000 RPM
- 1,728
- 34
- 152
06-12-2018, 09:18 AM #13
Always put new washers on the plugs
NEW Billet 3.0L seal carrier with 2.5 seals.
By Kenny Anthony in forum General Boating DiscussionReplies: 4Last Post: 10-01-2017, 06:01 PM -
2 jaw puller /carrier removal cle
By eli in forum Technical DiscussionReplies: 11Last Post: 03-15-2008, 12:29 PM -
300x upper seal carrier in billet..???
By godspeed in forum Technical DiscussionReplies: 1Last Post: 03-22-2007, 08:35 PM -
Carrier removal---how much heat???
By nelsoncat in forum Technical DiscussionReplies: 6Last Post: 04-22-2006, 09:04 PM
