Page 5 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 61 to 75 of 208
  1. #61
    I'm not familiar with that technology
    In post #15, i said
    "in 2019 I'd like to re-core the bottom, then go boating again before the summer is over"
    The core that I was refering to is foam core
    I want to add a core on the hull bottom where there is no core currently
    And where there is old core, I'd like to remove the old core replace with new core...foam core
    So, inorder for the core to be homogeneous, i have to make sure the core at the trailing edge of the transom is the same type of core that I will use on coring the rest of the hull bottom
    I can't re-core The hull bottom transom bedding once the transom is glassed on so I have to glass that foam coring now
  2. #62
    Happy Independence Day!
    time is really flying' now... but my work is sooo slow
    additional cleanup of the transom. cleaning along the angled area of the transom. found additional pure resin layups. There are no more pure resin left in the boat...all gone. Bye bye
  3. #63
  4. #64
  5. #65
  6. #66
    some design thoughts...
  7. #67
    Jun 2018
    Hudson, FL
    Noli are you trying to modify the design by adding foam that was never there? Thats not gonna help any why not just put out and buy more of those expensive Coosa Boards? You're not helping the hull any . . . .
  8. #68
    not modifying the design, just reinforcing the hull bottom which has no core. Eventually the foam core will spread across the rest of the hull bottom. when that happens, I'm already guaranteed that the transom area has foam because I put it there
    coosa will be used on the transom
  9. #69
    picked up this little puppy today
    https://www.screamandfly.com/showthr...38#post3059138
  10. #70
    Jun 2018
    Hudson, FL
    Did you buy your Coosa board yet?
  11. #71
    not yet....because of high temps in nj, I will concentrate on the motor for now
  12. #72
    Jun 2018
    Hudson, FL
    Where can I get the foam you're talking about Noli. That I can use polyester resin, not for boat use. Making a shaped part for a speaker.
    West Marine? Thanks
  13. #73
    Mar 2009
    Saint Lucie Florida
    Quote Originally Posted by DjliveX2018 View Post
    West Marine? Thanks
    Depends where your located but I see your in florida, West marine wont have products like that, check out Merrit Marine. They have coosa h80 and tons of other stuff.
  14. #74
    Jun 2018
    Hudson, FL
    I just went to see their website they have a lot Merrit Marine Supply Thanks!
  15. #75
