Page 14 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Results 196 to 208 of 208
  1. #196
    Minneapolis MN
    Good plan to keep an eye on the opening size of the hull. These things are incredibly flexible with the deck off. I brought my cradle all the way to the seam of the hull/deck.
  2. Thanks noli thanked for this post
    Likes noli, 89LASER liked this post
  3. #197
    got most of the flooring removed and exposed the end of the balsa core which is about 5 feet from the bow
  4. Likes 89LASER liked this post
  5. #198
  6. Likes tnelsmn, 89LASER liked this post
  7. #199
    Half of the flooring has been removed, and the balsa core on the port side will be 100% exposed and removed
  8. Likes tnelsmn, 89LASER liked this post
  9. #200
    If that doesn't make you itch, nothing will. I'm scratching my arms now......But, looks like good progress. Tear it all out and grind it clean...Carry on....
  10. Likes noli liked this post
  11. #201
    weather is getting nicer. Rainy here so been working indoors on removing the rest of the flooring
    before and after
  12. Likes 89LASER liked this post
  13. #202
  14. Likes tnelsmn, mrichartz, 89LASER liked this post
  15. #203
  16. Likes tnelsmn, 89LASER liked this post
  17. #204
  18. Likes tnelsmn, 89LASER liked this post
  19. #205
    Jun 2018
    Floating around
    Wow Noli that looks like a very hard strip down. Getting close to the fun stuff now tho
  20. Likes noli liked this post
  21. #206
    I can only work 1 hour at a time as I am sweatin' buckets in this hot weather
  22. #207
    Jul 2007
    Appleton,WI
    Any more progress made on the resto Noli? Im getting ready to open mine up this winter & looking at all my options. Have or what did you decide to go with for replacement core?
    Trying to be optimistic about my core cuz boat was built buy John Spaeth but preparing for the worst. My transom is showing its age & needs attention so I’m already in for that.
    X-Stream Vegas
  23. #208
    hi there.
    Will be back with more pics soon
    the running surface and hull sides will be divinycell foam
    transom and stringers will be coosa
    I used this to chop up and remove the wood core on my transom restoration , be very careful if you use this...scary!
  24. Likes 89LASER liked this post
