Page 13 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 181 to 195 of 208
  1. #181
    got my new toy for Father's Day
  2. Likes LakeFever, tnelsmn liked this post
  3. #182
    building hull supports to complete the core removal
  4. Likes tnelsmn, LakeFever liked this post
  5. #183
    Mar 2009
    Saint Lucie Florida
    JUst curious, but how do you go about cutting the wood to the shape of the bottom? lots of measuring? or can you trace the transom?
  6. #184
    first you create a pattern, then use the pattern to trace the shape onto heavier wood
    a pattern is a lightweight model of the shape you're trying to copy, made out of light materials like cardboard, and a hot glue gun
    the cardboard pieces or thin wood strips are cut small so as to follow the shape of the object you're trying to copy, and applying glue to "lock in" the shape you're trying to copy
    here's a video of how they copied the shape of the interior of the cabin with a v-shape hull for the bulkhead, again using hot glue gun and small wood strips
    you can fast forward to 6:50
  7. #185
    the youtube channel "SailBros" is actually one of my favorite channels
    they renovated this sailboat, pretty cool
    scroll down to the bottom (oldest video) and watch the video listings from the bottom up
    list of videos ==> https://www.youtube.com/channel/UC0Y...pY2X2aA/videos
  8. #186
    Mar 2009
    Saint Lucie Florida
    I got you oh, that's how I figured it was done and that's how I've done most of my templates I was just curious if there was another way with all the odd curves and shapes.
  9. Likes noli liked this post
  10. #187
    Australia
    Use a joggle stick. Much quicker.
  11. #188
    back on it because the temps are a lot cooler, during the day, the highs are upper 70*F
    very comfortable to work now
    I added different thickness of rug to the hull support to prevent scratching of the bottom and to create a tighter fit
    When I walked on hull it doesn't flex anymore because the templates are supporting not only the bottom but also the sides
  12. Likes tnelsmn liked this post
  13. #189
    Jun 2018
    Floating around
    Good to see you back at it! These resto threads are the most fun to watch. Go Noli!!!
  14. Likes noli liked this post
  15. #190
    if you do the hull supports after you've started the recore job, you can adjust each blade (of plywood) by using nuts and bolts for making the hull-support-plywood to rise to the hull then a few more turns to make the support nice and snug against the hull bottom
    I'm using different thickness home carpeting to prevent scratching the hull
  16. Likes tnelsmn liked this post
  17. #191
    Jun 2009
    Bristol, Connecticut
    I like your effort and progress so far! but I think those frames are a little over kill, I just put my Virage on 4 blocks (which is shaped similarly) and I didn’t notice any flexing while replacing the core because the intricate design of the bottom makes it strong by itself... more than one way to skin a cat...try not to deform the bottom with too much upward pressure, a lot of work restoring a boat so don’t waste too much energy on those frames!...here is my Virage:
ID:	449180Click image for larger version.
  18. Likes noli liked this post
  19. #192
    Aaron,
    you're 100% correct, these hulls have so many contours that they're already are well supported on their own
    I also use a 2' x 2' plywood with cushions to distribute my weight when inside the hull and grinding away the bad core
  20. #193
    The hull opening better not change during the build or the cap will not fit right. If the hull widens during the build (as a result of incorrect cradle) when the cap is put back, the cap might be too small
    to prevent the hull from widening during the re-core, I constantly measure the hull-opening and also make sure the cradle's side supports are snug against the sides
    Attached Thumbnails Attached Thumbnails 20190921_113356_001.jpg   20190921_113338.jpg   20190921_113338.jpg
  21. Likes tnelsmn liked this post
  22. #194
    now that the cradle is done (for now)
    I'm back inside the hull and found more wet core to do....yuuuk, more work!
  23. Likes tnelsmn liked this post
  24. #195
    The area marked in yellow triangle i believe is the core job that is waiting for me to do
  25. Likes tnelsmn liked this post
