Page 12 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 166 to 180 of 208
  1. #166
    pad core wet balsa
  2. #167
  3. #168
    Nowthen, Minnesota
    If the pad looks like that, you will be ripping up the rest of the boat and replacing that too. Gotta love that Hydrostream itch. A lot of us have been there. LoL
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
    1973 Hydrostream Vixen
  4. Likes noli, W2F a V-King liked this post
  5. #169
    is there a core on the hull between the pad the gunnel ?
  6. #170
    Nowthen, Minnesota
    Quote Originally Posted by noli View Post
    Yup, there is core on the outside of the stringers as well.
    Here is my vulture with the core done and gel coated over already. You can see it goes down the pad and then outside the stringers as well. You got a lot of ripping out to do. All the way to the bow of the boat and all the way out to both sides.
    -Kevin
  7. Likes noli, tnelsmn liked this post
  8. #171
    Nowthen, Minnesota
    Here is what my Vector looked like the day I bought it. You can see the area where the core is outside of the stringer box down the middle. All Hydrostreams have pretty much the same core lay out. There is more core in a vector and viper than a vking or vulture though. I personally dont own an XT hull so not sure about core in the gunnels.
    -Kevin
  9. Likes noli liked this post
  10. #172
    Minneapolis MN
    Hello my wetness, didn't expect to see you so spoon!
    I removed the skin covering the balsa core in the pad area, all wet, soaking wet
    first I used the circular saw just to score the skin, then completed the cut with that tool
    Attachment 439158
    Wow, looks like a lot of the core material came with the top skin! Was the rest of it adhered to the bottom well? Curious if it did this because its so wet or because it wasn't bonded to the hull that well to begin with. I really don't know, this is all new to me and I'm learning as I go.
    Great work, keep it going! Few of us are doing the same right along with you.
  11. #173
    tnelsmn
    I'm guessing its the water that broke the bond on both bottom and top of core
  12. Likes tnelsmn liked this post
  13. #174
    I removed part of the cockpit flooring towards the transom
    I took a sample of the stringer and it looks dry, but will be removing it nevertheless
  14. #175
  15. #176
    the hull bottom has a core from the stringer all the way to just before the sponson
    the core is a combination of balsa and pure resin
    you'll notice the pure resin because its green-like jelly appearance
  16. #177
    I've realized that that hull bottom is not all cored.
    I've been tracing the area of the hull bottom where there is balsa core and the area where there is pure resin
    shown here
  17. #178
    I'm thinking that a previous owner may have worked on this because the stringer is dry and looks new and also the balsa are inconsistent
  18. #179
    this little area was a very time consuming effort because I couldn't tell which way the balsa is laid out
    but I think that the rest of the port side core will follow this balsa-resin layout
  19. #180
    I exposed more of the core
    the balsa core widened as I moved towards the bow
  20. Likes tnelsmn liked this post
