Page 10 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 136 to 150 of 208
  1. #136
    Mar 2009
    Saint Lucie Florida
    Good choice.
    Quote Originally Posted by noli View Post
    yeah exactly,
    "yes we got core, now cover that up!...no one will ever see it"
    I'm glad to see the core, I'm not glad to embark on more work, but we're given another chance to make this hull better
    def no more wood will be placed in this hull
  2. Likes noli liked this post
  3. #137
    Jun 2018
    Floating around
    Exciting! What are you going to use in place of balsa?
  4. #138
    I'm thinking of using closed cell foam
  5. Likes TwzteD liked this post
  6. #139
    Jun 2018
    Floating around
    I like the idea of a composite core but the strength is considerably less than balsa so thats something to keep in mind during layup. I have chewed on this a bit and figure that the problem isn't the balsa, its the sealing of the core thats essential. With todays epoxies and putting on 3 or more good coats I think the balsa could be protected quite well, certainly better than original. That along with careful boat storage and maintenance has me thinking balsa is still the better route for me but I could be convinced to go composite still... Really curious to see how you make out Noli
    Any new core is exponentially better than rotten core though
  7. Likes nitro_rat liked this post
  8. #140
    balsa core def ranks among the top 3 for compression when its tubes are positioned 90* to the hull's bottom
    but people get sloppy, folks will penetrate the covering of the balsa core and there goes another core down the drain
    additionally, composite cores are very expensive
  9. Likes TwzteD liked this post
  10. #141
    Mar 2009
    Saint Lucie Florida
    Jul 2012
    Lufkin, Texas
    "Definitely among the top 3?" I don't have a chart handy but I've never seen any of the composite core manufacturers even claim that those products have anywhere near the compressive or shear strength of balsa. Not saying balsa is the only way to go. Many composites have been used successfully for many years. Some of the best built new SOB hulls are still built with balsa for a reason though...
    Quote Originally Posted by TwzteD View Post
    What are the top contenders?
    Divinycell, Corecell, Kledgecell are some of the top contenders. Also Baltek for end grain balsa
    No matter what materials you end up using the preparation and application are the most important parts. All composite can be done poorly and not last as long/take as much abuse as a balsa/ply build done correctly...
    Josh Peterson
  12. Likes TwzteD liked this post
  13. #143
    Nowthen, Minnesota
    I rebuilt my Vulture with marine ply and balsa. Plus balsa is much much cheaper. The way I figure, my Vulture was lasted 30+ built poorly, it should last way past another 30 rebuilt properly and much better. It really all comes down to preference I guess.
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
    1973 Hydrostream Vixen
  14. Likes LakeFever liked this post
  15. #144
    Like Hippie said, its more of a preference
    I talk with builders regularly and they're all going the foam direction
    so I will do the same, they have sold me on foam for now
    coosa, believe or not is a foam, but very dense and again very costly
  16. Likes TwzteD liked this post
  17. #145
    Mar 2009
    Saint Lucie Florida
    IM glad Im used H80 on my rebuild, its very easy to work with and very light, when glassed very strong aswell. Seems to be a great alternative, I have used 3/4 scored and scrimmed and 3/4 solid sheets. Coosa is nice also, just use a mask when cutting either its very fine dust cant be good to breathe in.
  18. Likes noli liked this post
  19. #146
    that's what builder-X uses on their hull running surface on their bigger models
    and the smaller models, they use H60
    cool!
  20. #147
    TwzteD, please share some pics
  21. #148
    I too would like to use scored, scrimmed, and perforated ==> http://www.diabgroup.com/en-GB/Produ...ishing-options
  22. #149
    Mar 2009
    Saint Lucie Florida
    Sure what would you like to see?
    My bulkheads, floor, gussets, splashwell, all 3/4 h80 transom and knees 3/4 Coosa 26.
    Floor has coosa plugs with t nuts glassed to the bottom so bolts can be used for strength and so it's water tight, I added foam to my boat since 13' in the ocean and don't want water to get it wet. Cap was cored with 3/4 scored h80. I aslo built a seat all out of h80.
  23. Likes LakeFever, JPEROG liked this post
  24. #150
    Mar 2009
    Saint Lucie Florida
  25. Likes noli, LakeFever, JPEROG liked this post
