Results 1 to 4 of 4
Thread: Evinrude thrust washers
05-30-2018, 08:01 PM #1Team Member
- Lake Coochiching, Ontario
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
Our new 150 HO came with a Viper prop. The thrust washer is too short to use a Renegade offshore prop. What thrust washer do I need?
Would the Viper or the Renegade thrust washer work with a Raker?
thanks
05-30-2018, 08:17 PM #2Team Member
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
or do I need this spacer?
http://www.crowleymarine.com/parts/13167.cfm
05-31-2018, 03:18 PM #3
Raker washer should work with Viper..... Renegade is much smaller in diameter... all need the splined spacer washer behind prop nut.
06-02-2018, 06:13 PM #4Team Member
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
It's a Renegade offshore, same hub diameter as the Viper and Raker. The Viper works without the spacer. I will try the spacer with the Renegade next weekend.
By David in forum Technical DiscussionReplies: 0Last Post: 05-28-2018, 12:02 PM -
OMC V4 Thrust Washers ?
By MattGreen in forum Technical DiscussionReplies: 2Last Post: 07-02-2008, 09:46 PM -
Thrust Washers
By OWENS1 in forum Technical DiscussionReplies: 3Last Post: 03-28-2006, 12:19 PM -
Prop removal and installation / thrust washers, tab washers, etc.
By stevek in forum Technical DiscussionReplies: 4Last Post: 10-01-2002, 03:03 PM
