Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 61 to 75 of 99
  1. #61
    May 2018
    Auburn NY
    Sorry, was 35 psi ( gauge pegged) at WTO, at idle or just off 5-10 psi, and 2000 rpm about 20 psi
  2. #62
    Nov 2016
    Missouri
    Quote Originally Posted by bullet123 View Post
    I'm not sure if it would create enough pressure to open poppet. I just reread this entire post. In post #1 you said you had 35 psi @3000 rpms and in post#13 you had 20 psi @2000-3000 rpms. Two totally different situations. Ideally you want 20-30 at WOT and 5-8 at idle. If you have a good psi gauge and your poppet is working properly, you should see pressure drop at around 2000 rpms when poppet opens (if my memory serves me right). Have you pulled poppet and made sure all parts are there?
    This is why i asked him if he pulled the poppet valve out and put the housing back on the block and then try flushing to see if there was water coming out where it should be.
  3. Thanks Dayton12 thanked for this post
  4. #63
    May 2018
    Auburn NY
    Just to confirm, and as stated in long test list, when poppet is out and flushed either back or through the water inlet lots water out of the poppet hole. With poppet valve in place, cover on, and full garden hose water pressure through the water inlet pipe, the poppet valve did not open.
  5. #64
    Apr 2017
    pa
    5 Post(s)
    Pressure that high points to restriction as stated earlier. Since you have flushed everything and you think poppet is working proper. Take it for a test drive. If you still have high pressure and overheat problem, then you need to find the restriction. Could be blockage in plates under powerhead or in the block itself. You said poppet and waterpump looked newer. Maybe previous owner replaced those parts in hopes it would fix problem and decided to throw in the towel.
  6. Likes pjbrownva liked this post
  7. #65
    Jul 2012
    Lufkin, Texas
    I’m thinking it’s not something simple.
    Josh Peterson
  8. #66
    Pekin, IL
    If you look at my first post you will see that is more or less my thinking also. Adapters plug and when they do you get ridiculous pressure and very hot very quick at wot. I suggested as a last resort since everything else is easy and quick to do. Fixing plate is fairly easy just a bit time consuming and will require a couple gaskets. Hopefully it don't get hot now so removal of the powerhead not necessary.
    Rock
    Team Junk
  9. Likes nitro_rat liked this post
  10. #67
    May 2018
    Auburn NY
    Ok, spoke to bullet (thanks) thinks W pump might be incorrect. After looking and more research, my serial number off the welsh plug shows it is XR6 (i have to add a zero in front of B otherwise search shows nothing), seems same as black max but merc cruiser parts diagram shows my water pump without the seal that slides down the driveshaft and sits on the top of the waterpump.
  11. #68
    Apr 2017
    pa
    5 Post(s)
    #36 in the diagram for your motorClick image for larger version.
  12. #69
    Pekin, IL
    If you have one or are in a position to get one I would love to see a picture of this powerhead.
    Rock
    Team Junk
  13. Likes nitro_rat liked this post
  14. #70
    new york babylon
    I had one that had massive wip but ran real Hot ,it was a pwrhd. I found ,the block. Head surface was not flat between cylinders and the compression was going into water jacket !!! That had me going for a few days,but not as bad as the flywheel that caused massive misfire after I changed every ING piece, then swapped wheel easy fix
  15. #71
    May 2018
    Auburn NY
    here is the powerheadClick image for larger version.
ID:	408990Click image for larger version.
ID:	408991Click image for larger version.
ID:	408992Click image for larger version.
ID:	408993Click image for larger version.
  16. #72
    Pekin, IL
    It's not an xr6. Looks like head marked 3 3/8. is this correct.
    Rock
    Team Junk
  17. #73
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by rock View Post
    I can’t read the mark on the head on my phone but it looks like a 2.4 175 to me.
    Josh Peterson
  18. #74
    Pekin, IL
    My guess also. Definitely not an xr6.
    Rock
    Team Junk
  19. #75
    Sep 2017
    Ashland city tn
    Looks like 3 3/8 under Dia on head. Looks like 2.0 to me
  1. 1985 Mercury 150 Black Max overheating
    By jdewaard in forum Technical Discussion
    Last Post: 08-26-2023, 07:38 PM
  2. Replies: 2
    Last Post: 08-15-2014, 07:18 AM
  3. how to bleed oil on a 1986 mercury black max 200
    By nubby in forum Technical Discussion
    Last Post: 06-24-2014, 09:56 AM
  4. mercury 200 black max overheating!!!! Please help
    By koshlakehydro in forum Technical Discussion
    Last Post: 05-30-2014, 09:36 AM
  5. 1986 Mercury Black Max carburetors, need help.
    By David@mpys in forum Technical Discussion
    Last Post: 06-17-2013, 10:12 PM
