Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 46 to 60 of 99
  1. #46
    May 2018
    Auburn NY
    I think my engine is 86-88 , there is one plate before the water pump cavity, that looks like only held in with silicone gasket.
  2. #47
    Jun 2012
    This is a 2 piece plate does yours look like this
  3. Thanks Dayton12 thanked for this post
  4. #48
    Apr 2017
    pa
    5 Post(s)
    Talon is talking about the piece or pieces below your powerhead. The cooling systems can be quite complex if someone has messed with it. Obviously someone has since therms are missing
  5. #49
    Jun 2012
    Could we get a picture or pictures for a visually aid please.
  6. #50
    May 2018
    Auburn NY
    would this be below the powerhead, looks like 2 pc, under the powerhead I can count three gaskets. Also mine is carb model most likely 1988
  7. #51
    May 2018
    Auburn NY
    thanks bullet, just sent out the same time you pointed out where I should be looking... thanks .
  8. #52
    Jun 2012
    Is your water pressure gauge piped into the top of the block?
  9. #53
    May 2018
    Auburn NY
    yes, just checked and appears to be.
  10. #54
    May 2018
    Auburn NY
    here is the picture, hope it helps.Click image for larger version.
  11. #55
    May 2018
    Auburn NY
    any comments on no water out of poppet when I was flushing from water intake side.... it only came out of tell tale hole.
  12. #56
    Nov 2016
    Missouri
    Did you try removing poppet valve and putting the cover back on to see if water comes out? and is there a spring in the valve.
  13. #57
    Apr 2017
    pa
    5 Post(s)
    Can you post serial number of powerhead? Should be stamped in a welch plug (size of a nickel) on top of powerhead
  14. #58
    May 2018
    Auburn NY
    Yes, there is a spring and yes tested with cover, under garden hose pressure with good tight fit, nothing from poppet only tell tale hole
  15. #59
    Apr 2017
    pa
    5 Post(s)
    I'm not sure if it would create enough pressure to open poppet. I just reread this entire post. In post #1 you said you had 35 psi @3000 rpms and in post#13 you had 20 psi @2000-3000 rpms. Two totally different situations. Ideally you want 20-30 at WOT and 5-8 at idle. If you have a good psi gauge and your poppet is working properly, you should see pressure drop at around 2000 rpms when poppet opens (if my memory serves me right). Have you pulled poppet and made sure all parts are there?
  16. Likes pjbrownva liked this post
  17. #60
    May 2018
    Auburn NY
    B130163 so should be 1987 correct?
  1. 1985 Mercury 150 Black Max overheating
    By jdewaard in forum Technical Discussion
    Last Post: 08-26-2023, 07:38 PM
  2. Replies: 2
    Last Post: 08-15-2014, 07:18 AM
  3. how to bleed oil on a 1986 mercury black max 200
    By nubby in forum Technical Discussion
    Last Post: 06-24-2014, 09:56 AM
  4. mercury 200 black max overheating!!!! Please help
    By koshlakehydro in forum Technical Discussion
    Last Post: 05-30-2014, 09:36 AM
  5. 1986 Mercury Black Max carburetors, need help.
    By David@mpys in forum Technical Discussion
    Last Post: 06-17-2013, 10:12 PM
