Results 1 to 2 of 2
05-22-2018, 08:18 AM #15000 RPM
- Sep 2006
- 456
- 160
- 9
- 43
- 49
Leaking out of newly intalled motor mount bolt
Water leaking from the newly installed solid motor mount out the left front bolt. I just put mounts . 2 piece mid 2.4. What have I done wrong?
I did silcon around the mount.
05-22-2018, 08:26 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Warped adapter plate maybe....I have developed the habit of running a large fine tooth file held flat on all the mounting surfaces to look for hi and low spots. It will surprise you when you do this on seemingly good, flat, parts. It just takes a little more time during assembly. But can keep you from pulling everything back apart.
Mercury Tech: Mercury 250EFI 3.0L water leaking from lower motor mount
By Motion22 in forum Technical DiscussionReplies: 7Last Post: 09-07-2014, 07:54 AM -
OMC Tech: 1985 175 omc leaking water from behind lower motor mount
By baddjonny in forum Technical DiscussionReplies: 5Last Post: 10-12-2011, 05:55 PM -
Mercury Tech: leaking water top motor mount/powerhead gasket
By lil dingy in forum Technical DiscussionReplies: 7Last Post: 09-05-2010, 01:18 PM -
rounded off motor mount bolt
By Riverratt in forum Technical DiscussionReplies: 9Last Post: 01-22-2004, 07:44 AM
