Results 1 to 11 of 11
Thread: What have I got
05-21-2018, 11:46 PM #15000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 192
What have I got
OK, just picked up what is supposed to be a Mercury 1974 long shaft 150 horse. Serial number 3915919, black painted motor, has distributor. The block is casting number is 852-6381 with a 2w under the casting number. Where it has a block for the serial number it says "FACTORY REBUILT" Motor is pretty clean, plug number 3 has metal on it, number 6 is covered in rust. lower unit looks clean, haven't checked the lube yet. Wiring isn't crumbled up. No tilt n trim. 100 bucks ????
05-22-2018, 05:26 PM #2
Used to be a motor, now its some parts you can part out.
05-22-2018, 06:49 PM #3Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
ya a hard man sammmm
GENE LANHAM liked this post
05-22-2018, 06:56 PM #4Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Consider it a wonderful opportunity to get familiar with the resurrection of tower of power , if possible.
05-22-2018, 09:54 PM #55000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 192
Ouch, could someone look up what the serial number says or better yet, tell me where I could look it up, I used to know but can't seem to find it anymore???
05-22-2018, 10:51 PM #6
I have an absolute sh*t ton of virgin Michigan fresh water internal parts free plus shipping for inline 6's. For dudes willing to keep these motors going.
05-23-2018, 08:01 PM #7
Merc serial numbers only tell the year, not the model
05-24-2018, 03:39 PM #85000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 192
Three ring, power port, believe high dome pistons. Number three is AFU, number six doesn't look too bad. I've heard reasons for numbers one and six being wiped out, but what takes out number three?????
05-25-2018, 06:00 PM #9
Number three is the big 6's hard luck cylinder. It fails more than 1 or 6
05-30-2018, 07:08 PM #10Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
The middle top monkey.....on pulse tunning gets hot from both ends. Merc made a dist plate that retarded #3. Clean up the bore with a Floppy wheel and put a slug in it and go on....... I use a Floopy as not to hone out just to get the burnt piston junk. Then hone.... Or send it to a shop that Knows blind bores and buy 6 nos .. nla pistons...
06-03-2018, 03:51 PM #117000 RPM
- Dec 2005
- 2,124
- 642
- 288
- 1920
- 949
- 3 Post(s)
