Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: 850 xs tower?
    WI
    It is a 650 XS, I found correct serial number list on www.oldmercs.com website.
    4304334
    1976 650 XS 4304325 and up and 90hp
    Building the puzzle and part of the fun is trying to finding all the pieces.
    I know a couple of guys that used to race these..hopefully they still have some pieces around.
  2. #17
    WI
    Thanks to all that helped figure this thing out!!
  3. #18
    Fond du Lac WI
    Quote Originally Posted by 53w View Post
    The 650xs was 3 cyl and 3 carb correct? How much hp?
    I figure i need at least 80hp to push the star around and get it to ride.
    If i can find a power head might make a good ride.
    The 650XS was around 86-88 hp at 7400-7600 RPM. They had a tendency to grenade if run over 8000 RPM. You will not find a powerhead, BUT, I do know of a very good complete 650XS in Michigan that is seriously for sale. I owned it and went thru it before I sold it to the current owner. It does not fit his Hydroplane application and wants to sell it. Coldwater Michigan, 5 hours from Fond du lac - I know because I delivered it when I sold it. Let me know and I will hook you up with the owner.Click image for larger version.
  4. Likes Mark75H liked this post
  5. #19
    South Florida
    11 Post(s)
    A perfect motor for a mid 70s SE boat. As an old E class driver I would love to run one of those motors. They came out right about the time I stepped away from racing.
  6. Likes Mark75H liked this post
  7. #20
    Feb 2005
    Ohio
    Horsepower for the Star .....
    ..... I figure i need at least 80hp to push the star around and get it to ride.
    Depends on what you think is a good ride. The 1100 gave it what I would define as a good ride. I wouldn't want anything less than that. If I remember correctly, the 1250 powerhead will bolt onto the housing you have. If you could find one of those from 1968, you'd love the ride and it would run forever ..... just my opinion.
  8. #21
    WI
    Quote Originally Posted by willabee View Post
    Willibee,
    I do trust and value your opinion. I still have not not gotten time to go through the 1100ss or work on the star.. I did find a good cdi box for it, so i should have spark.
    Every summer i have good intentions to work on it, but it never happens.. other stuff or other jobs that pay gets in the way...
    I am also putting together an studs up 1250bp clone to run on it.
    I also wanted to try to put together an nice shift engine to make sand bar hopping and docking a little bit driver friendly.
    Went over to my friends shop looking for a short short tower assembly for shift engine, says I got just what you need an 850xs hard mount race tower and take it and it free...but turns out it is really a 650xs.
    I am thinking on taking it up to Tomahawk WI for the antique outboard motor and boat show this summer. They are doing a big thing on Switzer Craft boats. Maybe back it in the water on trailer and see your old 1100ss and ssm will fire up.. I don't think i will have boat drive able by then, but engine should be ok to try to start.
    great to hear from you again
    53w
  9. #22
    Feb 2005
    Ohio
    Time .....
    Willibee, ..... I still have not not gotten time to go through the 1100ss or work on the star.. I did find a good cdi box for it, so i should have spark.
    I also wanted to try to put together an nice shift engine to make sand bar hopping and docking a little bit driver friendly. .....53w
    It's too bad you can't find time to get the Star running again, you're missing out on one hell of a lot of fun.
    As far as 'a nice shift engine' goes, you don't need it. You just need to learn how to drive it without, it's not difficult. You will give away way too much performance just to snuggle up to a bar dock and every Checkmate on the water will see that and want to race!
    That boat was built to intimidate, not accommodate.
  10. Likes Bob V, OLEGATOR liked this post
  11. #23
    WI
Name:	merc bouat house star 1100ssm.jpg
ID:	412920Click image for larger version.
ID:	412921Click image for larger version.
    Had it a Tomahawk WI antique outboard meet in 2014. First time I ever had it out of shop washed it and quick wax job.
    They having Switzer Craft boats as one of the main attractions this year up there in early August. Going to bring it back up there if weather is good. Has some transom and balsa core minor problems that need to be addressed, it been dry for over 30 years, so not trying to get it wet until I can fix it. Might throw good cdi box on it and fill ssm up with oil and back it in and see if it will start..
    53w
  12. Likes Bob V liked this post
  13. #24
    Which of the 3 possible distributors is on this motor?
  14. #25
    Feb 2005
    Ohio
    Shooting Star .....
ID:	412922 ...... it been dry for over 30 years, so not trying to get it wet until I can fix it. ..... 53w
    Probably been dry since about 1970, almost 50 years!
    It always was and still is a beautiful boat, fun memories.
  15. #26
    WI
    Quote Originally Posted by Mark75H View Post
    It is the early points triggered cdi system. One year only one. I was lucky enough to find a good spare dizzy and box that came off a running 950ss
  16. Likes Mark75H liked this post
  17. #27
    Fond du Lac WI
    53w
    Instead of tying up the ramps at T-Hawk, test it at home - ramp space can be at a preminum up there if the weather is good.
  1. Omc vs Tower of Power
    By jeepster21 in forum General Boating Discussion
    Last Post: 01-30-2008, 11:52 PM
  2. Will a 2.5 280 fit on a bridgeport tower?
    By KG4 in forum Technical Discussion
    Last Post: 08-10-2004, 08:05 AM
  3. tower of power Q
    By dorc in forum Technical Discussion
    Last Post: 07-13-2004, 10:25 PM
  4. 70-73 Tower Evo.
    By Clams Canino in forum Outboard and Racing History
    Last Post: 04-12-2004, 08:43 AM
