Results 1 to 2 of 2
    May 2018
    antioch ca.
    casale split case 12'
    hello brother boaters.iam new to v drives and need help to interpit the numbers on the gears I have.i have two sets the first reads 3.90 29T 1.48 LH and 43T 3.90 1.48 LH heres the second set.27T 8.78 1.63 12'and 44T 8.78 1.63 12' can anywon tell me about these gears I need to buy a prop what gears do I need for a lot of torq thanks for the help
    Sep 2018
    Wolverine Lake, Michigan
    Quote Originally Posted by coldhorse View Post
    LH means "Left Hand" over or the gears are machined for left hand rotation. 12' likely means 12 degree gears.
    The 29T and 43T represent the number of teeth on the gears. 1.48 is the overdrive ratio with the 43 tooth gear on top.
    43 divided by 29 = 1,4827 Or 48 % overdrive
    Similarly the other set 27T and 44T are the number of teeth. 44/27 = 1.6296 or 63% overdrive.
    I have no idea what 3.90 or 8.78 represents.
    Casale Engineering on Telegraph Road in Santa Fe Springs (562) 906-4825 has always been friendly and helpful to me.
    http://www.casalev-drive.com/
    JJ at Beaver Fab in Texas is a great guy as well.
    http://www.beaverfab.com/6248.html
    BeaverFab Inc. PO Box 453 Covington, TX 76636
    (254) 854-2083 jj@beaverfab.com
    I hope this helps, Darin
  1. casale toploader
    By Frankm246 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 12-01-2015, 07:51 AM
  2. Casale toploader gear lash
    Last Post: 07-08-2014, 11:35 PM
  3. Casale v-drive
    By FastLaser in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 07-31-2008, 07:52 PM
  4. Torque specs for the split case on 2.4
    By Pgnandt in forum Technical Discussion
    Last Post: 12-01-2002, 05:09 PM
