Results 31 to 45 of 47
  1. #31
    Aug 2018
    On a racetrack or at the lake
    Quote Originally Posted by JPEROG View Post
    We are very close to having the 300R motors hung on one. Hopefully within 10 days or so we will be running it. There was no need to rig the X motors for comparison, I have witnessed enough of the 300Rs to know that they are faster and better in every way. To rig it with the X's would have required extra holes etc. and I was not interested in doing that on a brand new rig.
    I know it’s not the same dyno, so not an exact comparison, but the R seems to make in between what the X and XS made...
    http://www.davebushracing.com/mercur...0x-update.html
  2. #32
    Torque is on an R is way more then an X or XS and probably close to what a 3.6 XS is. They are an incredible piece that runs on anything more then swamp gas.
    Jul 2013
    medellin colombia
    Any idea what the tq and hp numbers are on the 300 sea pro? Do the base seapro and xs have the same Length intake runners? Thx, Rm
  4. #34
    Jul 2013
    medellin colombia
    Quote Originally Posted by Radiant View Post
    I would like to see a 350 hp version. A 350r while still remaining naturally aspirated. The 300r only requires 87 octane. To me that makes it seem like there is some power left for later versions from merc. Although I would hate to buy a 300r now for my lake and bay, only for them to come out with a 350r in a year.
    i think what will be really interesting is if it can be tuned like a Yamaha VMax SHO
    I hear some of the 300Rs are breaking output shafts. I would think Merc will want to fix that before adding more hp
  5. #35
    There is a thread on here about the the prop shafts. They (merc.) are well aware of everyone that breaks (it cost them a ton of $$) to cover warranty claims when expensive propellers are lost in the process. The fix for this adds additional cost to the company which changes product profit estimates etc. etc. etc. and when you are owned by a massive corporation, anything that changes production processes and or alters profit forecast becomes a process of signatures and approvals to be implemented-much like the US congress, nothing happens fast. Its just part of operating with thousands of armchair warriors, board members and stock holders that look at paper and numbers to gauge their success.
    You can guarantee that if the guys on the front line could make the call it would have been done before the fourth or fifth one broke.
  6. Likes engineermike liked this post
  7. #36
    Aug 2018
    I understand the 4-stroke makes more torque below peak than the 2-stroke, but peak torque numbers seem similar between the 3. The fact that it makes the the power on regular 87 octane is plus over the older Racing 2-strokes.
  8. #37
    Aug 2018
    Quote Originally Posted by ratman67 View Post
    According to the Carb report below 300 SeaPro is detuned to 276hp@5500 and 298ftlbs@4500. Yes all 200-300hp V8s besides the 300R share the same parts except the throttle body, the 200-225 uses a smaller throttle body and the 250-300 gets the larger one. The rest is up to the computer tuning, the peak hp numbers of the 250Pro XS is the same as 300 Sea Pro for example though the 250 Pro XS makes 312ftlbs at the same Rpm.
    https://ww3.arb.ca.gov/msprog/offroa...w-001-0490.pdf
  9. #38
    Quote Originally Posted by PRE-Z06 View Post
    The torque down low is what you feel and what translates to acceleration. Torque makes something move, horsepower keeps it moving... When you run one and compare the two for yourself, it is very obvious.
    Aug 2018
    I agree, the 4-stroke will be easier to prop for holeshot. A properly propped 2-stroke that ventilates to the powerband would still give it a good run I imagine. It’s like a big block that doesn’t need a loose converter, but the hotter small block makes the same peak torque it just needs a higher stall to cut the same 60’. Once they’re moving down track, the hp as you said is what’s going to determine the top end speed.
  11. #40
    I thought there was a cam difference between 200-300?
  12. #41
    Aug 2018
    No, they’re the same part#s as can be seen below. Only the 300R has different cams, the two different size electronic throttle bodies 64mm and 80mm are what ultimately are limiting the amount of air able to be ingested which determines the peak hp number and why the lower hp engines peak at lower rpm than the higher hp ones as they’re essentially an airflow restrictor.
    https://www.mercurymarine.com/en/us/.../parts-catalog
  13. #42
    Feb 2014
    Missouri
    I would look at cam times as well. 3* +- is up to 20-30 hp.
  14. #43
    Aug 2018
    I agree advancing or retarding the intake cam 3* would change the output and shift the powerband up or down ~300rpm as that’s how Yamaha does it on the SHO with VCT, but Mercury chose a simpler/more reliable design in my opinion which I applaud with fixed DOHC. Being this is engine has an electronic throttle body like the SHO to limit airflow like it’s counterpart does as well for it’s 200-300hp versions of the same 4.2L V6. My guess is Mercury then uses torque based engine management to keep the powerband flat from peak onward with the lower hp models as noted in the carb reports. This keeps the engine from needing to be propped lower if the intake cam was only advanced to lower peak output as that would only cause the powerband to fall off faster at higher rpms resulting in a boat that wouldn’t run as fast on the top end. Torque based engine management has been around in the automotive world for some time...
    https://www.sae.org/publications/tec.../2001-01-0269/
  15. #44
    Variable valve timing will be coming at some point "assuming the market is willing to pay for the horsepower that it will be capable of creating". We are just seeing the tip of the iceberg for this platform.
    Aug 2018
    Agreed, it’ll help with emissions as well which unfortunately is going to continue to play more of a factor with the feared climate change propaganda. Making more power is easy these days, but stipulations make it more challenging and the complexity then adds cost as you’ve alluded to. The other thing that is not as big of a deal in the automotive world, but is in the outboard industry is weight. I’ve always been a fan of natural aspiration over forced induction weight being one of the reasons as well thermal, efficiency and the linear powerband. With more cubic inches comes more fuel burn and more RPMs creates more heat, so there has to be a balance. For reference the 350 Verado only makes 25hp and 9ftlbs more (341hp@5800 and 320@4500ftlbs according to CARB report) than the 300R, but weighs 156lbs more...
    https://www.arb.ca.gov/msprog/offroa...w-001-0477.pdf
  1. Mercury 300R Startup and Running Video
    By Scream And Fly in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 09-05-2018, 07:28 AM
  2. The Mercury Racing 250R and 300R details
    By WavetoWave in forum General Boating Discussion
    Last Post: 06-01-2018, 09:21 PM
  3. New! Mercury 250R and 300R
    By RUM RUNNER 305 in forum General Boating Discussion
    Last Post: 05-25-2018, 06:02 AM
  4. Video: Mercury 300R Startup and Running Video
    Last Post: 05-19-2018, 09:44 PM
  5. Mercury Racing Launches All-New 250R and 300R Outboard Engines
    Last Post: 05-19-2018, 05:25 AM
