Results 1 to 2 of 2
    Feb 2012
    ft myers florida
    22 velocity. Setback. Pros and cons.
    I would like to know pros and cons of diffrent setbacks on a 22 velocity? I am thinking between 6 and 8 inch setback?. Also Motor height?. Going to make transom to a 25 inch but could I run a 20 motor with setback? Maybe mounting jack plate a little lower to compensate for the 25 inch transom ? Going to 25 inch transom so I don't get the water splashing over transom.. knowledgeable input would be great.... thanks. Going with 2.5 Mercury to start. Then maybe a 3ltr as when I can afford it. Thanks again
    Yes to set back
    Any of those boats, the 22 and the 26 handle better with the engine set back. How much? I can tell you that one of the best running 26 (26 is just a 22 extended 4 feet and with higher sides) had a custom hydraulic set back that was about 18". Around 1995 the 22 mold was modified to move the step about 3 inches more forward.
    I don't care what anyone says about stepped transoms. It is not the same as moving the engines back from the transom with setbacks. Virtually any outboard boat has improved handling and performance from setback.
    Another thing about these boats, move as much weight aft as you can. If you have dual batteries don't put them under the seat, put them against the transom. The boat will run faster.
    1970 15' Allison/135 Chrysler stacker
    RC Mod-VP Boats
    IMPBA District 13
    NAMBA District 3
  1. Mercury Tech: 220 laser efi pros/cons
    By 86Eagle in forum Technical Discussion
    Last Post: 06-11-2015, 12:41 PM
  2. pros and cons
    By JJ QUEST in forum Technical Discussion
    Last Post: 07-20-2009, 05:23 PM
  3. Pros and Cons 250 EFI
    By Fish in forum Technical Discussion
    Last Post: 07-04-2004, 09:27 PM
  4. pros & cons.......
    By LiquidBoats in forum Technical Discussion
    Last Post: 09-08-2002, 11:22 PM
  5. Low compression, Pros,Cons
    By PIT BULL in forum Technical Discussion
    Last Post: 02-07-2002, 11:53 PM
