Results 16 to 22 of 22
Thread: OMC Turbojet , Pros & Cons
05-01-2020, 09:29 AM #16New Member
- May 2020
- Canada
Do you still have your boat jimmy?
Jon NL liked this post
05-01-2020, 10:18 AM #17New Member
- May 2020
- Detroit
No hoses at bottom of heads
I have a 1994 Boston Whaler Rage with a turbojet 115 I was going to move the hoses from the top of the heads but I dont have hoses going to the bottom of the heads what I have is 2 larger hoses going from the thermostat housing into the bottom of the heads did you change the hoses from the stat housing?
08-19-2020, 01:08 PM #185000 RPM
- Apr 2018
- Australia
- 134
- 26
- 13
- 22
- 34
g'day fishnchicks,, have been off line for a while , yes still have boat , do have some performance figures now , will post soon ,
powerabout thanked for this postJon NL liked this post
08-19-2020, 01:11 PM #195000 RPM
- Apr 2018
- Australia
- 134
- 26
- 13
- 22
- 34
you probly worked that out by now , sorry for the way to late reply , check waterfowl one any crossbow v4 , your answer is there ,
08-20-2020, 05:28 AM #205000 RPM
- Apr 2018
- Australia
- 134
- 26
- 13
- 22
- 34
This shows water off the top of the heads leading out to pee vents , the water exhaust jacket should have a tapped hole and plug , just like all outboards with this engine,, run this outlet to cool exhaust stream ,that's important,, check your water pressure at wot, s/b 20 psi , the problem im yet to overcome is water pressure at idle , or lack off , going to try a boost pump of a sort , will put that on soon , hoping to supply even 5 psi at idle would be great , also not happy with omc water supply check valve in stator , its a ****ty setup , prone to blockup to easy and starves the block of water , we need to fix this if we want reliabily , any ideas,,,,!cheers
10-15-2020, 08:09 PM #21
The adapter plates hold water in these things and crack..they do not self drain and need a shot of anti freeze to winterize. They were a semi solid unit otherwise.
10-22-2022, 06:10 PM #225000 RPM
- Apr 2018
- Australia
- 134
- 26
- 13
- 22
- 34
from the left to right ,#1, this $2 elbow has cost me thousands to finally realise its the whole problem of water supply , #2. location of elbow #3.. 3/4"bsp straight hose barb fitted into water gallery to filter,, the idea is , any debris that make it past the blow off valve will not get caught until the filter, were it can do no harm . #4 engine bay layout , big red hose not that pretty but works a treat , now at idle there's a steady 2-3psi to the motor ,then when Thermos opens, pee tails are still strong , same at wot , no change in water volume, im hopping there would be another owner prepared to try this because it feels like a eureka moment , I still love this boat , blown a lot of fuel through this thing and stil get the grin when you go past outboards where props fear to go , oh yeah motor mod with piston ports gives a great zinggy power band between 4800- 5700 rpm,,, over 13,000 views on this project and many more hours of fun ,many thanks to all, Regards Jimmybar
Pros and cons of an opti
By wottz in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 36Last Post: 10-23-2013, 07:47 PM -
Pros and Cons of this motor?
By FoFittyFoSS in forum General Boating DiscussionReplies: 8Last Post: 05-13-2013, 08:21 PM -
pros and cons
By JJ QUEST in forum Technical DiscussionReplies: 4Last Post: 07-20-2009, 05:23 PM -
Pros and Cons 250 EFI
By Fish in forum Technical DiscussionReplies: 8Last Post: 07-04-2004, 09:27 PM -
pros & cons.......
By LiquidBoats in forum Technical DiscussionReplies: 2Last Post: 09-08-2002, 11:22 PM
