Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
    May 2020
    Canada
    Do you still have your boat jimmy?
  2. Likes Jon NL liked this post
  3. #17
    May 2020
    Detroit
    No hoses at bottom of heads
    Quote Originally Posted by Jimmybar View Post
    YOU HEARD IT HERE FIRST. it was a painfull trail of piston grabs until the penny dropped, water pressure builds up in the exhaust stream when the engine is loaded , enough pressure to push the water back up the water bleed and create a air lock in the top head . the solution is but one. its cheap and effective. the real issue is the relief valve and bowl pressure. if your engine is modfied to make more HP . or your impeller has seen better days the bowl pressure will be affected. ofcourse there are other parameters that effect exhaust pressure . like load . fuel the list goes on . so I came up with THIS solution . vent top head water jacket. and voila . it works . most of the time. VERY CLOSE TO MOD 3 ENGINE BUILD will keep you posted
    I have a 1994 Boston Whaler Rage with a turbojet 115 I was going to move the hoses from the top of the heads but I dont have hoses going to the bottom of the heads what I have is 2 larger hoses going from the thermostat housing into the bottom of the heads did you change the hoses from the stat housing?
  4. Likes Jon NL liked this post
  5. #18
    Apr 2018
    Australia
    g'day fishnchicks,, have been off line for a while , yes still have boat , do have some performance figures now , will post soon ,
  6. Thanks powerabout thanked for this post
  7. #19
    Apr 2018
    Australia
    you probly worked that out by now , sorry for the way to late reply , check waterfowl one any crossbow v4 , your answer is there ,
  8. Likes Jon NL liked this post
  9. #20
    Apr 2018
    Australia
    This shows water off the top of the heads leading out to pee vents , the water exhaust jacket should have a tapped hole and plug , just like all outboards with this engine,, run this outlet to cool exhaust stream ,that's important,, check your water pressure at wot, s/b 20 psi , the problem im yet to overcome is water pressure at idle , or lack off , going to try a boost pump of a sort , will put that on soon , hoping to supply even 5 psi at idle would be great , also not happy with omc water supply check valve in stator , its a ****ty setup , prone to blockup to easy and starves the block of water , we need to fix this if we want reliabily , any ideas,,,,!cheers
  10. Likes Jon NL liked this post
  11. #21
    The adapter plates hold water in these things and crack..they do not self drain and need a shot of anti freeze to winterize. They were a semi solid unit otherwise.
  12. Likes Jon NL, Jimmybar liked this post
  13. #22
    Apr 2018
    Australia
ID:	511383Click image for larger version.
ID:	511384Click image for larger version.
ID:	511385Click image for larger version.
ID:	511386from the left to right ,#1, this $2 elbow has cost me thousands to finally realise its the whole problem of water supply , #2. location of elbow #3.. 3/4"bsp straight hose barb fitted into water gallery to filter,, the idea is , any debris that make it past the blow off valve will not get caught until the filter, were it can do no harm . #4 engine bay layout , big red hose not that pretty but works a treat , now at idle there's a steady 2-3psi to the motor ,then when Thermos opens, pee tails are still strong , same at wot , no change in water volume, im hopping there would be another owner prepared to try this because it feels like a eureka moment , I still love this boat , blown a lot of fuel through this thing and stil get the grin when you go past outboards where props fear to go , oh yeah motor mod with piston ports gives a great zinggy power band between 4800- 5700 rpm,,, over 13,000 views on this project and many more hours of fun ,many thanks to all, Regards Jimmybar
  14. Thanks powerabout thanked for this post
  1. Pros and cons of an opti
    By wottz in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-23-2013, 07:47 PM
  2. Pros and Cons of this motor?
    By FoFittyFoSS in forum General Boating Discussion
    Last Post: 05-13-2013, 08:21 PM
  3. pros and cons
    By JJ QUEST in forum Technical Discussion
    Last Post: 07-20-2009, 05:23 PM
  4. Pros and Cons 250 EFI
    By Fish in forum Technical Discussion
    Last Post: 07-04-2004, 09:27 PM
  5. pros & cons.......
    By LiquidBoats in forum Technical Discussion
    Last Post: 09-08-2002, 11:22 PM
