Results 106 to 120 of 163
Thread: 1998 225 Merc Motor HELP!!
05-19-2018, 03:02 PM #106Member
- May 2017
- 70
- 10
- 29
- 7
Thank you!!
05-19-2018, 03:05 PM #107Member
- May 2017
- 70
- 10
- 29
- 7
Thank you!! I just saw your location and we are actually in Chapmansboro which won't be far from you at all!!!
05-19-2018, 07:58 PM #108
I gotta chance to meet with Lauren and Brad. Looked motor over. It has no numbers on block except r p on Welch plug does look to be a painted Promax also has has Promax sound to it little bit. What is stock compression for 225 Promax? Would it have idle reliefs?
05-19-2018, 08:02 PM #109
No idle reliefs slots. 175 and 150 had idle reliefs . Should be 125 range.
05-19-2018, 08:05 PM #110
Only way I would know to tell for sure if it’s a promax since it’s black, is to pull intake and see if it’s a 7 petal and pull a head to look at porting
05-19-2018, 08:07 PM #111
I got 106 -115. Fire on all 6 on hose. Dnt sound like it's missing on hose. It's is leaking between block halves. Seems to b seal leaking not top cap seal. I'm afraid it's not enough compression. This is gauge I've tested all mine with. Did not get chance to do a leak down also he told me he has been slowly losing rpm. Started running 6200ish I believe and now down to 5200 and now Dnt wanna take off
05-19-2018, 08:13 PM #112
Did check fire with light on hose doesn't mean it won't lose it under load. But is this compression up to par for this motor. Or is this the reason he is losing rpms?
05-19-2018, 08:16 PM #113
Sry #2 or 4 was 100lbs
Lauren liked this post
05-19-2018, 08:19 PM #114
Leaking on both sides of block? Look like it got hot? Compression seems pretty low for any healthy
v6 merc unless it’s a slot motor. I would not be surprised if it’s a 175 fishing block
05-19-2018, 08:19 PM #115
I didn't get pull head as I wanted to. Do you no if bolt patten is same for 5 and 7 pedal or are the bolts n different places for 7?
05-19-2018, 08:22 PM #116
Actually there were a few air bubbles n paint but no discoloring and yes both sides
05-19-2018, 08:26 PM #117
Nothing jumped out at me like it had ran hot
05-19-2018, 08:27 PM #118
IMO. Motor is unhealthy. Either tear it down determine what you have and fix or just count your losses and try and trade it in.
05-19-2018, 08:31 PM #119
And that was bout my exact words. If it is a Promax. Should have a gud platform to start with. I think it's just lacking compression/power under load. Mine did same thing with low compression
05-19-2018, 08:32 PM #120
With the highest compression being 115 I have a feeling it is a slot block. Unless you gauge usually reads low
1998 promax 300 many problems with this motor
By cvp240 in forum Technical DiscussionReplies: 5Last Post: 02-20-2014, 07:39 PM -
1998 Optimax -150 hp .. Decent Motor?
By sschefer in forum Technical DiscussionReplies: 5Last Post: 10-18-2009, 11:01 AM -
OMC GEARCASE Q: WILL A 1998 60DEGREE V4 LOWER FIT a 1998 90DEGREE V4 Motor?
By joe-doggs in forum Technical DiscussionReplies: 7Last Post: 09-13-2003, 06:56 PM
