Results 1 to 6 of 6
    Mar 2018
    North west Missouri
    Splitting the hull on an astro
    Turns out the boat I thought had no foam in the hull, has tons of it. I'm going to have to pull it all. Pretty sure the only way to get to it is to split the hull. Any tricks to getting the splash well off? Any secrets that will help speed it up. Actually, any info would be great.
    Jul 2012
    Lufkin, Texas
    A pressure washer will cut right through the stuff. Have a helper keep the drain plug hole clear...
    Josh Peterson
  3. Likes turnerlittle liked this post
    Mar 2018
    North west Missouri
    Thanks. That's a good idea. Looks like someone has had it off before. I have all the screws out and it seems to be just sitting there now. I'm gonna unhook the hoses and such tomorrow.Click image for larger version.
    Mar 2018
    North west Missouri
    Just in case anyone is keeping up with this. You can't split the hull on a 93 astro bass boat. The foam is spread between the deck and hull with no plastic barrier. So the boat is effectively glued together with a great amount of surface area. You can still get the foam our though.Click image for larger version.
    Big Pine Key FL.
    How did it work out for you? I m thinking of buying a 93 astro 20fsx and was curious if there were any transom issues. Thinking of hanging my 250 pro xs off of it.
    thanks,
    Bryan.
    [/SIGPIC]SIXX9.
    1979 SCORPION 21 PROJECT DEVILFISH.
    Mar 2018
    North west Missouri
    Its built like a tank. I've had no issues with the transom on mine.
  1. Splitting a 2.5 Merc Case
    By Von in forum Technical Discussion
    Last Post: 07-02-2010, 10:09 AM
  2. Help splitting hull on Ebko Stinger!!
    By 71Stinger in forum Fiberglass and Composites Discussion
    Last Post: 10-12-2009, 04:53 PM
  3. Thinking of splitting up 260?
    By stoneman in forum General Boating Discussion
    Last Post: 10-21-2007, 06:57 PM
  4. Splitting 84' Merc 115 block/mid
    By On Tap in forum Technical Discussion
    Last Post: 01-15-2006, 05:01 PM
