Results 1 to 8 of 8
Thread: tilt trim wiring
05-07-2018, 01:56 PM #15000 RPM
- Sep 2016
- haliburton
- 211
- 10
- 7
tilt trim wiring
Im trying to put the steering wheel mount trim tabs on my steering wheel there is 3 wires one up one down and one power there is 2 wires from the trim tilt motor how do i hook this up?
05-08-2018, 02:13 PM #26000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
The wires on the switch activate the relays. Red is power into the switch. Green is powet out down (think green like grass) and blue is power out up (think blue like the sky). The relays switch the positive to the trim motor from blue to green (depending on if you are going up or down) and suply ground to the other.
If you already have a trim Switch t the helm you can just tee into it.
05-08-2018, 02:24 PM #35000 RPM
- Sep 2016
- haliburton
- 211
- 10
- 7
I havent seen any relays anywhere in my motor? i will try and get some pictures this weekend
05-08-2018, 05:45 PM #4
What motor you you have might help
05-08-2018, 05:58 PM #55000 RPM
- Sep 2016
- haliburton
- 211
- 10
- 7
sorry ya 225 omc
05-15-2018, 11:52 AM #67000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
I have a 225 omc also. I hooked up the blinker style trim switches too. It takes 2 relays wired up to reverse the motor. Not hard to do, but I found a diagram to reference. My original relays were bolted to the motor originally I believe. I moved them when I wired it.
05-15-2018, 11:54 AM #77000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
http://www.chattanoogafishingforum.c...sts=10&start=1
Not the same one I used but hope it helps
05-21-2018, 12:09 PM #85000 RPM
- Sep 2016
- haliburton
- 211
- 10
- 7
thanks but i had to sit down drink a case of beer and draw it out on the beer case
Aftermarket trim: Panther power trim and tilt bracket opinions?
By mxz in forum General Boating DiscussionReplies: 4Last Post: 10-28-2016, 06:05 AM -
Tilt/Trim Wiring Help
By Contractor in forum Electronics, Audio Systems, and WiringReplies: 3Last Post: 06-27-2011, 08:25 PM -
Johnson 140hp 1977 trim tilt wiring ?
By phillnjack in forum Electronics, Audio Systems, and WiringReplies: 1Last Post: 03-04-2011, 08:34 PM -
Tilt n tilt wiring 1977 johnson 140hp ?
By phillnjack in forum Technical DiscussionReplies: 6Last Post: 02-28-2011, 01:47 PM -
OMC Tech: 2-piston trim system won't TILT up, but WILL trim up
By pcrussell50 in forum Technical DiscussionReplies: 2Last Post: 08-20-2010, 03:41 PM
