Results 46 to 60 of 64
05-04-2018, 09:00 PM #46James H. W2F a V-King... Want 2 Fly a V-King
05-05-2018, 08:05 AM #47
It just takes a while to fully cure, I'm not looking to have the boat running until the end of summer anyway, so it'll have plenty of time to cure. One other thing, this boat has the typical stress cracks in the corners of the transom well. I drilled a couple of holes into the transom, and the wood looks good. Is it possible that the transom is good even though the core is bad?
05-06-2018, 07:13 AM #48
What would everyone suggest to do the floor in? It's only 24" wide, and maybe 8 feet long. Should I just use the h80 divinicel?
05-06-2018, 06:11 PM #49Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
How you plan on mounting the seats?
05-07-2018, 05:54 AM #50
1/2 Coosa cloth lay up on both sides. I made a aluminum plate and drill/taped mounting holes in it for a seat slider. epoxied it down. Then lay up a piece of cloth over it. stick bolts in the holes till just about set up.
05-07-2018, 06:28 AM #51Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
May have to make a base....They come with a box that goes side to side that the seats mount to.
05-07-2018, 07:18 AM #52
I was going to delete the bench and build boxes once I know what seats I'm going with. I was thinking of glassing in 1/4" aluminum plate, and drill/tap it for seat mounting. I have 1/2" divincel h60 left over from another project. Can I use it for the floor? Floor is roughly 2ft wide by 9 feet.
05-07-2018, 07:37 AM #53Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Would work fine..Make a floor panel out of the boat and tab it in.
05-07-2018, 02:13 PM #54
https://www.iboats.com/shop/garelick...cts%3AShopping
Use this no box needed just mount to the 1/4" plate on the floor.Last edited by dwilfong; 05-07-2018 at 02:15 PM.
05-08-2018, 06:14 AM #55
After talking to several people who know hydrostream, I decided to keep the original seat bench design, but won't make it as tall. Apparently it adds to the rigidity of the boat (ties the boat together across). I'll make it out of divincel, and Glass aluminum plates into the top to mount the seats
XstreamVking liked this post
05-15-2018, 07:27 AM #56action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
05-15-2018, 07:28 AM #57
All done, just have to glass the seat bench in.
05-15-2018, 06:26 PM #58The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
mrcrsr liked this post
05-15-2018, 06:27 PM #59The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
05-16-2018, 11:29 AM #60
I’m going to be doing the same on my viper, great info Thxs. 1 question though, how much materials did you go with. I read about 5gal epoxy resin. How much d-cel sheets and 1708 rolls did you get?
1983 hydrostream viper
150 merc
hydrostream viper core and transom
By nohasslekindaguy in forum Fiberglass and Composites DiscussionReplies: 14Last Post: 03-21-2017, 09:12 PM -
Viper partial re-core
By ViperVince in forum Fiberglass and Composites DiscussionReplies: 59Last Post: 01-06-2011, 05:43 PM -
Viper: is a GOOD re-core more or less a permanent fix?
By pcrussell50 in forum General Boating DiscussionReplies: 2Last Post: 07-11-2010, 07:07 PM -
73 Viper - Is there core under the deck?
By Riverman in forum Fiberglass and Composites DiscussionReplies: 13Last Post: 01-11-2006, 11:00 PM
