Results 106 to 120 of 280
Thread: Finally, 21 Skater Twin
05-06-2018, 06:44 PM #1065000 RPM
- Apr 2005
- Long Island NY
- 541
- 10
- 19
- 159
- 218
05-06-2018, 06:53 PM #107TRANSPORT SERVICE...UP TO 36 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY.
LIVE LIFE ON THE EDGE, LESS CROWED BETTER VIEW
NICE PAIR liked this post
05-07-2018, 01:13 PM #1088000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
Frank Molé liked this post
05-10-2018, 07:03 PM #109
Things are moving along
Finished moving the batteries to the front.
Batteries - 2 x 44.4lbs = 88.8lbs
Battery Holders - 2 x 3.6 = 7.2lbs
Total = 96lbs
I did glass some 3/4 plywood in to strengthen it up, plus extra material to screw down, probably another 5-10lbs
I like the blinker style trim behind the steering wheel controlling both motors, so I made a prototype bracket out of wood, and will have my machinist friend make it out of stainless.
Finish one project, another pops up.................
Next project straightening out the wiring
05-10-2018, 08:07 PM #1105000 RPM
- Jan 2014
- Illinois
- 770
- 12
- 89
- 382
Mine just got home from paint some paint work. Battery’s up front are key. Oddesyy battery’s aren’t much more money and weigh 26lbs each.
05-10-2018, 09:48 PM #111
Looking good Steve!
Larry Gempp Jr.
Esox4130 liked this post
05-11-2018, 11:09 AM #112
The white 21 looks real nice, seems you already did everything to her, anything left?
As far as running, at WOT what trim are the motors at, negative?
I assume you have thru hull water pickups, any chance you can post a pic of them, and any mods to the bottom to work in conjunction with them
Thanks
05-11-2018, 12:01 PM #1135000 RPM
- Jan 2014
- Illinois
- 770
- 12
- 89
- 382
There’s always one more thing to do lol. As far as water pickup I don’t run any. Motors are bolted to the transom and as high up as they can go which is even with bottom. I have the water ramps cut in on bottom of boat. I water pressure issues gauges are always pinned when running fast. I use a lot of trim and about 70mph start coming Down to around level or when it feels planted good. It you go wide open with a lot of trim from 30-40mph boat won’t ever porpoise. And come down at 70mph plus. If your slowly picking up speed the boat will porpoise from 55 to about 70 mph and after 70 rides flat on rails. I had a tunnel tab and that worked great for cruising at 55-70 mph. It had it removed when had painted to save some weight in the boat. Tom Kennedy has the diagram to cut the raps if you message him. Text or call me if you have any questions 6306753792
Frank Molé, AZMIDLYF liked this post
05-11-2018, 05:06 PM #114
is gone
05-11-2018, 07:51 PM #115
As always, thanks
Frank Molé, BUZZIN' DOZEN liked this post
05-11-2018, 10:09 PM #1165000 RPM
- Apr 2005
- Long Island NY
- 541
- 10
- 19
- 159
- 218
Water ramps are not really necessary. I've modified water ramps on a few 28 skaters with 300x. My motors are mounted right on the transom, no setbacks and I've never had a problem with water pressure. As a matter of fact I have three water dumps coming out of my motors. One out of the poppet valve plate and one on each head. (Nice sketch Buzzin)
05-12-2018, 09:41 AM #1175000 RPM
- Jan 2014
- Illinois
- 770
- 12
- 89
- 382
my dad cut them in my boat when he owned it. Had same motor overheat and burned it up twice. He cut the ramps and it’s never had that problem again. Think it lost pressure taking long sweepin turns. I thought about filing them when boat was re done. Water pressure gauges are 25-30 psi when taking long curves at 80-100 mph. But I imagine you loose a few mph up top with water directing up to the gear case more.
05-14-2018, 07:46 PM #118
05-15-2018, 06:22 PM #119
05-15-2018, 07:19 PM #120
24 skater finally
By warren in forum General Boating DiscussionReplies: 33Last Post: 12-12-2012, 01:51 PM -
FINALLY!!! My 21 Skater re-rig / Interior Is completed.
By chrislopez1313 in forum General Boating DiscussionReplies: 33Last Post: 09-02-2011, 07:04 PM -
Bought A 24 Skater Finally!!!!!!!!!
By Viper GTs in forum General Boating DiscussionReplies: 3Last Post: 04-28-2009, 06:03 AM -
finally went for a ride in the skater
By dan1731 in forum General Boating DiscussionReplies: 34Last Post: 02-17-2009, 06:15 PM -
Pics..Skater is done, finally!!
By tzrider in forum General Boating DiscussionReplies: 28Last Post: 01-17-2008, 05:16 PM
