Results 106 to 120 of 165
Thread: Omc 140hp cross flow
06-13-2018, 12:34 AM #1065000 RPM
- Apr 2018
- Australia
- 134
- 26
- 13
- 22
- 34
with the rods I balance the little ends first on a pivot , then adjust the big ends, to 1gr... the pistons,,,will check squish zone with plastsine ,then going to cut the skirt to allow for max intake to the crown at TDC and wide enough to allow for the four ports to take a breath . bit different to a scallop on the 9 pages..then take them to within a 1gr as well , somewhere near the mark ???
06-13-2018, 08:31 AM #107Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I was thinking to get the slide rule out and see the area of the scallop versus slotted piston?
06-13-2018, 05:11 PM #1085000 RPM
- Apr 2018
- Australia
- 134
- 26
- 13
- 22
- 34
yes , that's one part . then add induction port timing . then crankcase compression timing. add a bit of assumption on pulse timing . sprinkle with anticipation. and" whoa lah". see you on race day !!!.PS reality is . we have a passion for these old bangers . and love it .cheers
06-13-2018, 07:45 PM #109
My Baja 15ss ran 62.9 with a stock, carbon encrusted '83 140. Bolted on the transom.
Run 66.7 with a fresh "7 1/2 paged" '77 140 on a 4" jackplate.
In retrospect. Next time I'm just gonna buy a bigger motor ...'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
Jimmybar liked this post
06-17-2018, 10:37 PM #1105000 RPM
- Apr 2018
- Australia
- 134
- 26
- 13
- 22
- 34
NOW THAT'S JUST TO EASY ..Ha Ha hahaha
06-18-2018, 05:35 AM #111"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
06-18-2018, 05:37 AM #112
I should have asked where the prop shaft hight was in relation to the hull bottom?
Gary"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
10-03-2018, 04:42 AM #1135000 RPM
- Apr 2018
- Australia
- 134
- 26
- 13
- 22
- 34
FMP liked this post
10-03-2018, 04:49 AM #114Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
did you machine the block to match the piston?
10-03-2018, 05:46 AM #1155000 RPM
- Apr 2018
- Australia
- 134
- 26
- 13
- 22
- 34
10-03-2018, 05:53 AM #116Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
you said airflow much higher, how are you measuring that?
10-03-2018, 06:05 AM #1175000 RPM
- Apr 2018
- Australia
- 134
- 26
- 13
- 22
- 34
Sit down, grab a beer. and get your head around this , I set up a compressed air jet into the intake duct then set a db meter at different spots . piston chamber. intake transfer. crankcase area . and measure the db sound level at different crank angle tdc to bdc . this gave me a measurable difference at different points. put that info on a graph. tried factory . 9 pages .and mod 3 . the higher the pitch and sound the faster the air , and lower db's more volume , bit out there . but so is science , its the pulse wave . that's the one . want more ???
10-03-2018, 06:17 AM #118Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
ok, I can understand that.
you said you kept burning pistons, what mod caused that?
10-03-2018, 06:58 AM #119Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Hey Jimmy,
Good stuff , too bad about the burn! Where's the burn, on deflector, all pistons. Just picking up this read again , this burn is recent?
10-03-2018, 11:28 AM #120Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I wonder with a stock engine or even a scalloped block, can you use a bypass cover that has a floor in it to help turn the flow to 90 degrees and into the cylinder?
Now we are trying to get flow into a sharp edged port
OMC Tech: Cross Flow 150 vs 185
By LSaupe in forum Technical DiscussionReplies: 15Last Post: 01-08-2010, 09:25 AM -
Omc 25 H.p. - Cross Flow-
By DonChicho in forum Technical DiscussionReplies: 1Last Post: 08-01-2006, 09:13 PM -
Cross flow
By woody in forum Technical DiscussionReplies: 8Last Post: 06-07-2003, 10:25 PM
