Results 1 to 2 of 2
04-24-2018, 04:23 PM #15000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
Products for coating and painting the Merc gearcase this weekend?
Hey so I already have some alodine 1201 and alodine 1132. I can't find a solid set of instructions on the quickest way to get a decent corrosion protection job on the lower unit. I don't care too much about looks. Need to have the materials this weekend so I can finish and launch the boat on Sunday for the year.
I'm in the middle of deciding which alodine will be easiest, 1132 pen vs getting some etchant and using 1201.
Should i used a primer? what brand?
What paint can people recommend that I can get by this weekend?
Anyways this spring I found the ground cable from the transom mounts to the exhaust housing had broke and the two anodes on the lower unit were no longer electrically connected to the lower unit. Go figure from all the galvanic corrosion. Also interesting is the 4 year old SEI gearcase took all the corrosion and the 23 year old Mercury exhaust housing looked almost untouched. My 1st guess is that SEI used a more galvanically active alloy and it started to corrode or they could have just used inferrior coatings.
After breaking the grounding bolt and drilling a very nice hole in the bolts for 45 minutes I snapped off the easyout. I then drilled and tapped a new grounding wire on starboard side installed the mercury wire and checked that everything was connected by multimeter.
I also replaced all zinc anodes with the aluminum alloy ones from boatzincs and I replaced the prop thrust fin with one that was also an anode.
04-24-2018, 05:06 PM #25000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
So my plan is to clean and sand the housing. Scotchbrite and 120 grit sandpaper should do the job.
Not sure about degreaser to use still.
Then ill use a phosphoric acid based metal etch.
Then use an alodine 1132 pen.
Followed by a coat of Quicksilver gray spray paint primer,
Followed by 2 coats quicksilver phantom black spray paint.Last edited by Fishinmymission; 04-27-2018 at 02:41 PM.
Powder coating on gearcase??
By JUPITER PULSARE in forum General Boating DiscussionReplies: 35Last Post: 07-29-2015, 11:15 AM -
Merc 280 NICON coating?? What is the inspection procedure?
By Djohns in forum Technical DiscussionReplies: 5Last Post: 02-26-2011, 07:20 PM -
Painting Aluminum vs powder coating
By Carlson150XS in forum Appearance ModsReplies: 13Last Post: 06-07-2010, 11:07 AM -
painting gearcase
By SteveO in forum Technical DiscussionReplies: 6Last Post: 10-19-2002, 12:04 AM
