Results 1 to 2 of 2
04-24-2018, 03:09 PM #1
Sportmaster lower shift shaft seal
I noticed fluid coming from the top of the lower unit ,I had just replaced the shift shaft seal, went in nice and tight when I removed it the shift shaft seal was 1/2 out . I know people say to let a little fluid out when u change fluid am I maybe not letting enough out and the pressure is pushing it out ? Thx for any info
2003 mirage ski racer with e-tec power
NICE PAIR liked this post
04-24-2018, 06:08 PM #2
I believe the correct amount of lube in the sporty (dry) is 28oz. If I had to guess dry to overflow would be a quart + lets just say 33/34 oz.
I've had very good luck when done filling with motors vertical, I take out the top plug and let it temp-cycle (open-drip) for two days, then cap it up.
you probably could (with the top plug in) pull the bottom plug and drain off 2oz.
my $ .02Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
dgscroggs thanked for this post
Lakeland marine shift shaft seal
By bradmd in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 15Last Post: 03-02-2018, 06:30 PM -
3.0 Sportmaster Billet Seal Housing & Shift Shaft Housing
By alli-runner in forum General Boating DiscussionReplies: 4Last Post: 12-27-2010, 08:25 PM
