Results 1 to 4 of 4
    Apr 2018
    Titusville Florida
    Will a late 90's 2.5 200 EFI power head fit on my 1991 2.4 liter XR4 150 midsection?
    I am wanting to upgrade to a 2.5 200 EFI. But rather than switch engines I was thinking maybe I could just find a good 200 EFI power head to put on my midsection. But if it will not fit, that's not going to work. So before I go searching for one I figured I would check with the experts first. Does anyone know if it is compatible and if it will fit under my cowling?
    Florida Keys
    Should work just fine
    '95 STV "The Blue Goose"
    Aug 2009
    mpls,mn
    yep
    Mar 2010
    houston, tx
    Exhaust ports on the 2.4 adapter plate are a little bit smaller, might loose some top end pull at the very top of the range like 6k plus.
    Other than that will work fine.
  1. Late 1995 mercury 2.5 260 power head minus ecu
    By superboattwin250 in forum Misc. Parts and Accessories
    Last Post: 01-29-2017, 07:07 PM
  2. Mercury 2.4 DROP-ON rebuilt power-head (late '80's 200HP) FS
    By centuryclub1990 in forum Outboard Engines
    Last Post: 12-02-2015, 12:13 AM
  3. Late 80 2.0 liter Merc 135 power head part out
    Last Post: 01-30-2015, 08:58 AM
  4. 2.4 liter power head on a 2.0 liter mid and lower????
    By Will I Am in forum Technical Discussion
    Last Post: 03-09-2007, 10:09 PM
