Results 46 to 60 of 496
Thread: 13' Bullet 130 Rebuild & Repower
05-24-2018, 04:18 PM #46
05-24-2018, 06:29 PM #47
89LASER liked this post
06-04-2018, 05:09 PM #48
06-05-2018, 06:19 AM #495000 RPM
- Jan 2004
- Lindenhurst, NY
- 658
- 87
- 64
- 3364
- 267
Flat black will be hot in the sun, plus the salt will show.
06-06-2018, 08:41 PM #50
06-08-2018, 04:29 PM #51
06-10-2018, 07:48 PM #52
Got the fresh skin down another big step, good amount of work, But thanks to GORILLA0178 on here we got it banged out in an hour or so! Next step is to order some Coosa for the transom for sure, on the fence for stringers, Coosa 15 or dcell H80? Coosa is cheaper, but id assume heavier also, 5lb vs 15lb. Not sure yet. here is some pics.
06-10-2018, 07:57 PM #53
Corelite board makes great strong stringers. Think 26lb. is what I used in mine. Easy to work with. I bought 1/2 thick.
https://shop.corelitecomposites.com/...nt=25549423238James H. W2F a V-King... Want 2 Fly a V-King
06-10-2018, 08:04 PM #54
im trying to keep the weight as low as possible on this boat, its going to float a heavier engine, im leaning toward h80 due to its 5 lb density vs the 15 coosa and the 26 coosa. we are going to doubble 3/4 to make 1.5" so the floor have a nice wide surface to bond to
06-11-2018, 11:03 AM #55
That's a good point making it with h80.
1.5" wide h80 will make it lighter for sure and easier with the larger area for a wider radius to get the 1700 to make the sharp turn up and over the top lay down when you cover the stringers. (If your covering your stringers this way)
Not sure but 1708 for covering the stringers (as the attached csm 3/4 oz I believe) will help make both inside and outside radius turns lay down without bubbling.
I used 1708 on my 1/2" stringers and it laid down nicely over on the radius turns. I Did filet the inside turns with thickened resin though... Took some extra rolling as the epoxy began to set to get a nice turn and covering with near 100% contact. 1/2" wide isn't much area to work with.
Great project and really nice work your doingJames H. W2F a V-King... Want 2 Fly a V-King
06-11-2018, 01:23 PM #567000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
So heres my thought, and everything is up to discussion and change. Coosa transom,H80 for deck and stringers. Deck could be Nida core, but foam is nicer to work with. 3/4 h80 doubled up with a 1708 between them. 2x1708 on each side with overlap on top, so it'll have 4 layers on the top. Then glued into the boat, 3 staggered layers of 1708 on each side with the last layer going to the top. A couple bulkheads in between the stringers. Deck would be 3/4 h80 with 1708 on bottom and 1708 and prob a 3/4 mat on top. Top cap needs core of some kind. It should get a fresh 3/4 mat on it then core of some kind. Nida will work good or scored and scrimmed foam. Then maybe 1208 on top of whatever core is used. Theres A lot to do and things can change, but I think hes headed in the right direction.
06-11-2018, 01:38 PM #57Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
This sounds like a good plan.....
TwzteD liked this post
06-12-2018, 10:50 AM #58
Placed an order today for a sheet of coosa 26 3/4 and two sheets of H80 3/4 will be using coosa for transom h80 for stringers and floor.
06-12-2018, 11:03 AM #59Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
The gorilla knows glass very well. And is very meticulous with it. Can't go wrong with him helping you.
06-12-2018, 06:49 PM #60
Evinrude XP200 Rebuild or Repower
By Stoker88 in forum Props, Setup, and RiggingReplies: 6Last Post: 09-09-2020, 11:06 PM -
83 Bullet Rebuild Update
By One Oldman in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 06-02-2013, 10:10 PM -
30' velocity rebuild/repower/reeverything
By biohzrd in forum General Boating DiscussionReplies: 66Last Post: 08-03-2010, 10:39 AM -
Repower advice: OptiMax or rebuild 2.5EFI
By mercfan1 in forum General Boating DiscussionReplies: 8Last Post: 11-11-2008, 09:02 PM
