Page 33 of 34 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 LastLast
Results 481 to 495 of 496
  1. #481
    Mar 2009
    Saint Lucie Florida
    Mar 2009
    Saint Lucie Florida
    Here's a few shots, boat needs to be setup, but happy for first splash, got 52 at 5300 rpm, got 1000 to gain and plenty of water pressure, needs to come up and the tunnel boat prop has no cupping and its big so that dont help.. ill take it for the first run, need to get used to the boat also find what it likes.
  3. Likes tnelsmn liked this post
  4. #483
    Mar 2009
    Saint Lucie Florida
  5. Likes LMT383, tnelsmn, V pads, rgsauger liked this post
  6. #484
    Mar 2009
    Saint Lucie Florida
  7. Likes LMT383, tnelsmn liked this post
  8. #485
    Mar 2018
    Laval, Quebec, Canada
    Thumb up Keep posting as you improve your setup. 2-3 vids would be great.
  9. Likes TwzteD liked this post
  10. #486
    Mar 2009
    Saint Lucie Florida
  11. Likes LMT383, tnelsmn, V pads, 89LASER, bullhead00 liked this post
  12. #487
    Minneapolis MN
    Love the flag on the transom!
  13. #488
    Mar 2009
    Saint Lucie Florida
    Quote Originally Posted by tnelsmn View Post
    Thanks! Everyone seems to love that I do myself too!
  14. Likes tnelsmn liked this post
  15. #489
    Mar 2009
    Saint Lucie Florida
    Still working on figuring setup out, got a few videos up of it in case you wanted to take a look, still not 100% where i want it but gaining little by little every time i go out.
  16. Likes 89LASER, LMT383, tnelsmn liked this post
  17. #490
    Manahawkin, NJ
    Looks like you got it running pretty good. I wouldn’t go any higher if you’re going to continue to run at high speed. The stream from the pisser is very week. Try plugging the top 2 or 3 holes. Nice Job��
    13' Bullet 60 Merc
  18. #491
    Mar 2018
    Did you improve your top speed?
  19. #492
    Mar 2009
    Saint Lucie Florida
    Quote Originally Posted by Nice Dreams View Post
    It's In spec, I have a water pressure guage and smartcraft, was runing from 120-130°. I'm going to be adding scoops to the gear case to see if it helps I had plenty of water pressure until I start trimming a little past neutral so with the scoops it should be perfect, that's as high as I can go without running a jack plate It's bolted straight to the transom so I'm going to see what kind of performance I can get out of it like this. Now that I know I have enough water pressure and adding scoops will likely boost it a lot because if you look there's still a lot of water shooting up from the bullet right past the the inlets so the scoops will catch a lot of that water. The problem is all of my props are too big I'm still about a thousand RPM short, The only prop that has reached the limiter is 11x18 regular cleaver but that was bouncing off the rev limiter at 6250 RPM all of my props including the one in this video are around 5,200 RPM, I did however throw my four blade cleaver back on and picked up a few miles an hour by raising the engine a few holes since the last time I tested it. Every time I go out I gain a little bit nothing crazy Still have to work on figuring out what kind of props this boat likes I have only tried cleavers and semi cleavers so far So I'm going to be borrowing a chopper from someone to see that maybe the ticket The boat does need a little bow lift so we'll see.
  20. Likes 89LASER liked this post
  21. #493
    Mar 2009
    Saint Lucie Florida
  22. Likes LMT383 liked this post
  23. #494
    Jul 2005
    panama city,fl
    I have a 2006 60 fourstroke on a 15 foot trihull and it runs 130 degrees also with the motor way low on transom so your temps are fine.Click image for larger version.
  24. #495
    Mar 2009
    Saint Lucie Florida
  1. Evinrude XP200 Rebuild or Repower
    By Stoker88 in forum Props, Setup, and Rigging
    Last Post: 09-09-2020, 11:06 PM
  2. 83 Bullet Rebuild Update
    By One Oldman in forum Fiberglass and Composites Discussion
    Last Post: 06-02-2013, 10:10 PM
  3. 30' velocity rebuild/repower/reeverything
    By biohzrd in forum General Boating Discussion
    Last Post: 08-03-2010, 10:39 AM
  4. Repower advice: OptiMax or rebuild 2.5EFI
    By mercfan1 in forum General Boating Discussion
    Last Post: 11-11-2008, 09:02 PM
