Page 3 of 34 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ... LastLast
Results 31 to 45 of 496
  1. #31
    Mar 2009
    Saint Lucie Florida
    Does the bottom have any cracking? If no, I would not core it. Maybe just add a layer of 1708 for insurance. Cover it with some light mat where you plan on grinding and /or gelling it. Vinyl is worth the x-tra money imo. Very good adhesion and strength. But, is not a must as long as the surface is clean and ruffed up. Transom is where I would really beef it up for jumping waves and such. Build the trans once and be confident in it not ever failing.
    Well, there are a few area that will need repair, looks like gel only, no damage to the glass that I can tell. There's only like 3 spots.
  2. #32
    The "star" crack might be at the end of a stringer or bulkhead making contact with the hull on the inside. Other crack looks to be a minor gell crack like you said. If that is all you have, it appears to be good to go. I don't think coring will be needed. imo
    Mar 2009
    Saint Lucie Florida
    Oki will just add a fresh layer of 1708 on the bottom and up the sides. Then reinforce the transom with multiple layers before adding coosa.
    This is the only stringer system the boat had, basically a tub premade then dropped in and glassed. Nothing very good. Once that was removed there nothing. That's why I was figuring coring, buy if it's not needed I do t want to waste the money.
  4. #34
    Just duplicate the reinforcement placement they had and you should be ok. 4 stringers with a floor over it would be about right. The tall tub uprights gave a lot of strength to the original design.
    Mar 2009
    Saint Lucie Florida
    Ok, Thanks for the help! Got the insidee all hit with the grinder, hopefully enough for some fresh glass to stick.
  6. #36
    Jun 2010
    over there a minute ago
    Looking good , TwzteD !!! Getting one ground down and ready to put back together is no easy feat . But you did it . All of the advice XstreamVking has given you is sound advice . As I'm sure you can tell , this is obviously not his first rodeo and with his support and your wallet and labor I have a feeling that you are going to have that Bullet flying through the air again in no time .
  7. #37
    Mar 2009
    Saint Lucie Florida
    Quote Originally Posted by capt bart View Post
    Its getting there, About to order some materials here shortly. Any benefit by going with red MEKP vs clear?Will either of these work or is one better than the other?
    http://www.merrittsupply.com/product...bute_color=Red
    http://www.merrittsupply.com/product...talyst-gallon/
  8. #38
    You don't need the red. It's for spray systems. You do need to get the correct mek for the resin you are using. Vinyl uses it's own mek. Also a gallon of mek will do a 55 gallon drum of resin. You are using a couple/3 5 gal buckets, get the small mek containers that come with the 5 gal buckets. Mek goes bad quick in the fla heat. You might use at most 2% by volume with the resin.
    Mar 2009
    Saint Lucie Florida
    Thanks for that info, I'm glad you told me, I will be buying 5 gal bucket of vinyl, as far as MEKP is concerned I can't find any info on what one would work, in the description all it says is to use 1-2% MEKp. Should I get 8 oz 16 oz? Will this one work?.
    Thanks again for all the help Xstream.
    https://www.merrittsupply.com/produc...alyst-bottles/
  10. #40
    Just call your order in to merritt and they will get you the hardener you need for the vinyl. Usually each 5 gal pail has a bottle of mek in the corresponding amount that they sell with it.
    Mar 2009
    Saint Lucie Florida
    Ok, great, thank you.
  12. #42
    Mar 2009
    Saint Lucie Florida
  13. Likes 89LASER liked this post
  14. #43
    There use to be a video gallery here, long time ago, that had videos of sharkey playing out in the ocean around one of the piers with his bullet.
  15. #44
    Mar 2009
    Saint Lucie Florida
    They are still on his website
    http://www.timsharkey.com/bullet-130-videos
  16. #45
    Yeah I saw but couldnt get them to play.
  1. Evinrude XP200 Rebuild or Repower
    By Stoker88 in forum Props, Setup, and Rigging
    Last Post: 09-09-2020, 11:06 PM
  2. 83 Bullet Rebuild Update
    By One Oldman in forum Fiberglass and Composites Discussion
    Last Post: 06-02-2013, 10:10 PM
  3. 30' velocity rebuild/repower/reeverything
    By biohzrd in forum General Boating Discussion
    Last Post: 08-03-2010, 10:39 AM
  4. Repower advice: OptiMax or rebuild 2.5EFI
    By mercfan1 in forum General Boating Discussion
    Last Post: 11-11-2008, 09:02 PM
