Page 26 of 34 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 LastLast
Results 376 to 390 of 496
  1. #376
    Mar 2009
    Saint Lucie Florida
    Notice that there is not one hole through the floor, when I pulled the plugs from the floor, I started with a drill bit in the hole saw shallow and after it was started pulled the bit out and finished with just the hole saw, not only is it a cleaner install, and looks more professional but it will keep my foam under the floor dry I don't see it getting wet unless somehow a hole gets poked in in. Thanks to Gorilla for the pro tip, hopefully someone else can use it on their project.
  2. #377
    Aug 2015
    NE Tennessee
    Will there be another sheet of glass over the seating area, covering those plugs?
    Looking really nice...and hand grenade proof for sure !!
  3. #378
    Mar 2009
    Port Saint Lucie
    Yes, there will be at least 1 maybe 2 1708 and CSM over the plugs. Prob a strip covering all 3 of them wider than the aluminum base. So the base will sit on a nice flat pad of glass.
  4. Likes W2F a V-King liked this post
  5. #379
    Mar 2009
    Saint Lucie Florida
    Quote Originally Posted by W2F a V-King View Post
    Yes of course, getting glued in soon, then glassed over.
  6. Likes W2F a V-King liked this post
  7. #380
    Mar 2009
    Saint Lucie Florida
  8. Likes LMT383, tnelsmn liked this post
  9. #381
    Mar 2009
    Saint Lucie Florida
    Drilled out the glass over the holes, mounted everything and it all fits perfectly. Started mocking up foot throttle base and footboard.
  10. Likes W2F a V-King liked this post
  11. #382
    Mar 2009
    Saint Lucie Florida
    Figured id post a few boats that have the same engines as mine to get an idea of how fast it will be, these boats are 16' and weigh around 1200lbs i should be around 900. My boat also has a flat pad and these have a concave pad. its a popular engine in the Uk, they run them on a few differnt hull styles.
  12. Likes W2F a V-King, home made tunnel liked this post
  13. #383
    Jul 2005
    panama city,fl
    Quote Originally Posted by Gorilla0178 View Post
    https://www.youtube.com/watch?v=Brfv73tZnas&t=55s
    Video. He wants to run in the ocean and not worry about anything structurally failing. So it's built like a tank. But lite as poss too.
    Well you guys did a great job building a tank! Probably snap something off the motor before hull cracks!
  14. Likes TwzteD liked this post
  15. #384
    Mar 2009
    Saint Lucie Florida
    Got a few small things done this past week. Got shifter mount glassed and glued in, got the foot throttle mount glued in and the foot board glassed, just have to glass the throttle mount and tab in the shifter mount, the footboard will be tabbed in later after the bottom is done as I need to flip the boat again to finish the bottom and the saw horses sit on the floor.
  16. Likes LMT383 liked this post
  17. #385
    Mar 2009
    Port Saint Lucie
    We'll get it all glassed soon.
  18. #386
    Mar 2009
    Saint Lucie Florida
    Shortened the wiring harness by taking 6ft off, soldered everything back up, had to add extensions for the blinker style trim switch since it's no longer going to be used on the shifter. I also jumped the neutral safty switch ( not shown ) to allow to start in gear ( big cleaver )
  19. Likes tnelsmn liked this post
  20. #387
    Mar 2009
    Saint Lucie Florida
    So Keith and I got a few things done on the boat yesterday, finished the bottom of splashwell, tabbed in shifter mount, glassed in foot throttle mounting pad. Basically all the glass work is done minus tabbing top to bottom and splashwell to transom. Just have to glue and glass the foot board also, next is lots of sanding and filling and sanding inside for gelcoat prep. Oh and my new stainless wheel finally came in!
  21. Likes tnelsmn liked this post
  22. #388
    Mar 2009
    Port Saint Lucie
    Nice wiring job. Wheel looks nice. Better than the plastic one.
  23. Likes TwzteD liked this post
  24. #389
    Mar 2009
    Saint Lucie Florida
    Got a last minute cosmetic thing done today, I like the clean look, so I added some angled core to the cap for the rigging tube flange and hydro steering bulkhead fittings for a much nicer cleaner look, it also channels all wires and cables into the channel for the wires up under the cap without any sharp angles. Just have to grind some gelcoat off the top and glass over them and through the hole and up under the cap for strength
  25. Likes tnelsmn liked this post
  26. #390
    Mar 2009
    Saint Lucie Florida
    Glued footboard in today also, cockpit is almost 100% only 1 guage for water pressure, I made a special mount for my phone to run The Merc vessel view app and all the rest (gps,rpm,temps,fuel) will be Bluetooth to my phone.
  27. Likes tnelsmn liked this post
  1. Evinrude XP200 Rebuild or Repower
    By Stoker88 in forum Props, Setup, and Rigging
    Last Post: 09-09-2020, 11:06 PM
  2. 83 Bullet Rebuild Update
    By One Oldman in forum Fiberglass and Composites Discussion
    Last Post: 06-02-2013, 10:10 PM
  3. 30' velocity rebuild/repower/reeverything
    By biohzrd in forum General Boating Discussion
    Last Post: 08-03-2010, 10:39 AM
  4. Repower advice: OptiMax or rebuild 2.5EFI
    By mercfan1 in forum General Boating Discussion
    Last Post: 11-11-2008, 09:02 PM
