Results 376 to 390 of 496
Thread: 13' Bullet 130 Rebuild & Repower
05-07-2019, 08:30 PM #376
Notice that there is not one hole through the floor, when I pulled the plugs from the floor, I started with a drill bit in the hole saw shallow and after it was started pulled the bit out and finished with just the hole saw, not only is it a cleaner install, and looks more professional but it will keep my foam under the floor dry I don't see it getting wet unless somehow a hole gets poked in in. Thanks to Gorilla for the pro tip, hopefully someone else can use it on their project.
05-08-2019, 12:25 PM #377
Will there be another sheet of glass over the seating area, covering those plugs?
Looking really nice...and hand grenade proof for sure !!James H. W2F a V-King... Want 2 Fly a V-King
05-08-2019, 12:32 PM #3787000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Yes, there will be at least 1 maybe 2 1708 and CSM over the plugs. Prob a strip covering all 3 of them wider than the aluminum base. So the base will sit on a nice flat pad of glass.
W2F a V-King liked this post
05-08-2019, 12:34 PM #379
05-08-2019, 07:41 PM #380
05-09-2019, 07:39 PM #381
05-13-2019, 08:16 PM #382
Figured id post a few boats that have the same engines as mine to get an idea of how fast it will be, these boats are 16' and weigh around 1200lbs i should be around 900. My boat also has a flat pad and these have a concave pad. its a popular engine in the Uk, they run them on a few differnt hull styles.
W2F a V-King, home made tunnel liked this post
05-26-2019, 12:45 PM #383
TwzteD liked this post
05-26-2019, 01:25 PM #384
Got a few small things done this past week. Got shifter mount glassed and glued in, got the foot throttle mount glued in and the foot board glassed, just have to glass the throttle mount and tab in the shifter mount, the footboard will be tabbed in later after the bottom is done as I need to flip the boat again to finish the bottom and the saw horses sit on the floor.
LMT383 liked this post
05-26-2019, 05:47 PM #3857000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
We'll get it all glassed soon.
05-27-2019, 05:42 AM #386
tnelsmn liked this post
06-01-2019, 05:02 AM #387
So Keith and I got a few things done on the boat yesterday, finished the bottom of splashwell, tabbed in shifter mount, glassed in foot throttle mounting pad. Basically all the glass work is done minus tabbing top to bottom and splashwell to transom. Just have to glue and glass the foot board also, next is lots of sanding and filling and sanding inside for gelcoat prep. Oh and my new stainless wheel finally came in!
06-01-2019, 05:33 AM #3887000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Nice wiring job. Wheel looks nice. Better than the plastic one.
06-02-2019, 10:26 AM #389
Got a last minute cosmetic thing done today, I like the clean look, so I added some angled core to the cap for the rigging tube flange and hydro steering bulkhead fittings for a much nicer cleaner look, it also channels all wires and cables into the channel for the wires up under the cap without any sharp angles. Just have to grind some gelcoat off the top and glass over them and through the hole and up under the cap for strength
06-02-2019, 11:43 AM #390
Evinrude XP200 Rebuild or Repower
By Stoker88 in forum Props, Setup, and RiggingReplies: 6Last Post: 09-09-2020, 11:06 PM -
83 Bullet Rebuild Update
By One Oldman in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 06-02-2013, 10:10 PM -
30' velocity rebuild/repower/reeverything
By biohzrd in forum General Boating DiscussionReplies: 66Last Post: 08-03-2010, 10:39 AM -
Repower advice: OptiMax or rebuild 2.5EFI
By mercfan1 in forum General Boating DiscussionReplies: 8Last Post: 11-11-2008, 09:02 PM
