Results 211 to 225 of 496
Thread: 13' Bullet 130 Rebuild & Repower
09-21-2018, 06:06 AM #211
Definitely feels solid, Anyone have any tips on "blueprinting" / leveling out the bottom?
09-21-2018, 05:25 PM #212
NICE PAIR liked this post
09-21-2018, 08:16 PM #2137000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Should be done tomorrow. A little putty, a really small 1.5 oz Matt, a 6 inch 1708 and a ripped 1.5oz over the whole thing to blend it in.
09-22-2018, 06:54 AM #214Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
On your blueprinting... Mark a line from each outside chine edge port and star across the transom. Measure up to the strakes and the bottom at equal measurements on each side of the transom. See what you have from side to side for variances. This is the starting point. Use a 6' straight edge or string and go fwd on the hull from the measured points on the transom and see what you have as far as hook and rocker. I usually only concern myself with the back 1/2 of the hull. Main thing is to have close to the same shape on each side of the hull. Some hook is good. Rocker will make the boat porpoise. Flat is good since you can add hook to control ride attitude if needed. If it is about 1/16'' to 1/8'' from side to side it will be ok at your speed level. Sharp strakes will def help performance as will a sharp trailing edge.
W2F a V-King thanked for this postNICE PAIR liked this post
09-22-2018, 08:44 AM #2157000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
What he said
09-22-2018, 08:58 AM #216
Sounds good, that's next after the floor gets glassed in.
09-22-2018, 06:29 PM #217
09-22-2018, 06:59 PM #218Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Torn mat makes such a good transition...Something a lot of people don't take the time to do....
09-22-2018, 07:18 PM #2197000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Mat makes everything nicer. It's hard to tell. But the transition from deck to Hull is pretty smooth. Nice and Even. Did a good job.
09-24-2018, 06:24 AM #220Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I would glass in a block of coosa for the bilge pump to mount to. Unless you plan on using silicone to mount it.
10-01-2018, 08:51 PM #221
I glassed in a block of wood for everything I mounted in my tunnel hull. DANG - I never thought of just 5200 to hold in my bilge pumps. But that would have worked great. jk!
A couple rough waves, and that would work it's way loose. Agreed, put a block of coosa down.1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
10-04-2018, 04:58 AM #222
10-04-2018, 06:13 AM #223Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
10-04-2018, 07:24 AM #224
I will probably just use 5200 like I did on my jet ski the pump never moved at all.
10-09-2018, 06:17 AM #225
Evinrude XP200 Rebuild or Repower
By Stoker88 in forum Props, Setup, and RiggingReplies: 6Last Post: 09-09-2020, 11:06 PM -
83 Bullet Rebuild Update
By One Oldman in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 06-02-2013, 10:10 PM -
30' velocity rebuild/repower/reeverything
By biohzrd in forum General Boating DiscussionReplies: 66Last Post: 08-03-2010, 10:39 AM -
Repower advice: OptiMax or rebuild 2.5EFI
By mercfan1 in forum General Boating DiscussionReplies: 8Last Post: 11-11-2008, 09:02 PM
