Results 1 to 4 of 4
    May 2007
    Fuel Regulator Mercury '96 150 EFI
    Does anyone know if there is an aftermarket source for the fuel regulator on a '96 150 EFI. Cheapest new I can find is $209, Already dumped a ton in this motor
    ECM repair at Simon's Motorsports, three different HP fuel pumps (new), new low pressure pump. What's left? Tired of being the guppy! Thanks for your help.
    This is a great website.
    Jul 2009
    Texarkana,AR
    Do you need the gold 39lb regulator? If so I have one I’ll send it to you.
    May 2007
    Thank you bb18. Not sure of the color, bu I think it is silver. It is a Kehein. It is raining right now. As soon as it stops I will go check it, and let you know Again, thank you.
    May 2007
    bb18. Thank you for the offer but my regulator is silver. It may not be a 39lb. It may be a 36lb. Thanks
  1. Mercury 300 Pro Max Fuel Pressure Regulator
    By thooker in forum Technical Discussion
    Last Post: 07-10-2017, 05:15 PM
  2. Mercury 300X Fuel pressure regulator
    By DCBMilt in forum Parts Wanted
    Last Post: 12-13-2016, 03:57 PM
  3. Mercury ECU and fuel pressure regulator chart
    By Chummy in forum Technical Discussion
    Last Post: 10-13-2016, 05:53 PM
Spinelli Props
