Results 1 to 3 of 3
Thread: Day 2 lighten up the sleekcraft
04-18-2018, 07:57 PM #1Member
- Aug 2010
- Breezy Point,Minnesota
- 32
Interior- tanks- carpet is out. Floor is .750 thick with a lot of resin. It lays right up to the outside stringers. Measures 4x8.like to replace with a light product. Anybody work with coosa board? How about a lightweight ply? I ground down to the wood , seems good and solid.Having trouble with images for some reason.Any response would be helpful.
07-23-2018, 10:40 PM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
If the wood is good.... leave it as boat builders... might have an idea...strong floor/bottom.Not all boats are potato chips.....
07-24-2018, 06:18 AM #3Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
While plywood is good floor material, it is heavy. The same strength could be achieved by using coosa. A 3/4'' 26# density coosa panel with 1708 on the underside and 1 layer of 1708 covered by a layer of 1.5oz mat on the top would be plenty strong. Wont hold screws so you would have to make a plan for that. Not really a big deal though. 3/4 plywood is 70#'s or so, and with the same glass on it weighs nearly 100#'s. Coosa would come out at about 30#'s less. So it comes down to needing to shed the 30#'s. The cost would be 500 - 600 bucks to use the coosa 1708 and vinyl resin. Slightly more for epoxy resin.
wtb lighten et
By boatskipper76 in forum PropellersReplies: 1Last Post: 07-14-2014, 10:53 PM -
Lighten flywheel
By ares650 in forum Technical DiscussionReplies: 25Last Post: 06-30-2004, 11:04 PM -
lighten rod weight
By bits&pieces in forum Technical DiscussionReplies: 9Last Post: 04-05-2004, 08:21 PM -
Lighten flywheel
By dc96819 in forum Technical DiscussionReplies: 1Last Post: 02-25-2004, 06:50 AM
