Results 16 to 17 of 17
04-16-2018, 01:42 AM #166000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Well
they are mounted backwards iirc port should be starboard but that’s an old debate.
Your deep and and that will transmit more water changes.
Something is making a prop pulse like splash on the starboard side and sometimes port. Which make no sense with water over the big plate.
Trim also looked out out of sync
10-20-2018, 10:48 PM #17
You said the props were cupped when you got them? Possibly could one ear been cupped more than the rest
Or to a different pitch? I personally had a 30 et on my e tech that had lab work done that I felt a noticable difference in vibration, which I believe to possibly have been in error in lab work ? Any thoughts?Last edited by Will hedrick; 10-23-2018 at 07:27 AM.
Mini Speed Boats, Long or Short Shaft Motors?
By rustymarine929 in forum General Boating DiscussionReplies: 2Last Post: 12-29-2014, 01:13 PM -
what speed should I expect from 12' baja with various size motors
By john rowley in forum Props, Setup, and RiggingReplies: 2Last Post: 08-11-2008, 05:58 AM -
Crackhead, shaking from withdrawl
By pyro in forum The Scream And Fly LoungeReplies: 4Last Post: 05-20-2004, 12:22 PM -
shaking mota
By merc326 in forum Technical DiscussionReplies: 0Last Post: 05-13-2004, 02:19 PM
