Results 1 to 15 of 17
04-12-2018, 05:43 PM #1New Member
- Sep 2013
- Alabama
PLEASE HELP why are my motors shaking at speed?
I took delivery of Competition 25 last summer. I have put about 70 hours on her and am trying to figure out the strange shakes the motors have while running. The shake are completely random and feel like they are getting turbulence. I have already reached out to Ken at prop gods and his suggestion was to try to lower the motors one hole. I lowered them and the shake has improved some but still present. I ironically did not loose any noticeable performance or fuel economy. I am running Yamaha Reliance props that I believe have been cupped when motors were hung. The boat performs great except for the very annoying shakes.
Please note that the videos and photos were taken before I lowered the motors one hole.
Can ventilation cause these shakes or is there something else causing this?
I am completely lost and hopefully some of you experts can help out.
https://www.youtube.com/watch?v=_IFjoSJ6C4s
https://www.youtube.com/watch?time_c...&v=zUG1eA7I630
https://www.youtube.com/watch?v=WpQN8tjpSRM
https://photos.app.goo.gl/rsS8x7cqhVIiPmlS2
04-12-2018, 06:06 PM #25000 RPM
- Jul 2013
- Corunna ontario
- 116
- 9
- 27
air in the hydraulic steering would be my first guess
04-13-2018, 07:28 AM #3New Member
- Sep 2013
- Alabama
The steering ram does not move when the engine shakes. If it was air I would expect both engines to shake due to tie bar.
04-13-2018, 07:32 AM #4
It almost looks like the steering ram connection to the motors is using a rubber bushing and isn’t a hard connection like it should be. Hard to see in the video but it looks like the motors tillers are moving when the ram connection isn’t.
Mark
04-13-2018, 10:15 AM #5Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Motors are moving independently. Best guess....Bad rubber on the engine mounts. May have been beat hard b-4 you got them?
04-13-2018, 10:28 AM #6New Member
- Sep 2013
- Alabama
The boat is brand new. I only have 70 hours on her. If mounts are bad then they have been bad since day one.
04-13-2018, 10:35 AM #7
Props that are slipping or venting can cause vibration, when it does it try changing trim setting and see if vibration changes.
04-13-2018, 11:34 AM #8Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
It sure seems to be moving the cowls and power heads around. Steering is solid. When the boat is out of the water, try and move them around by stepping on the cav plate and springing up and down some and check for movement.
04-13-2018, 11:42 AM #9New Member
- Sep 2013
- Alabama
Seems like the put really soft motor mounts on these new motor but something else has to bee going on to cause the shake.
04-13-2018, 12:14 PM #10Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
You might check for the alignment of the gear cases. Nose centers and prop shaft centers should be close (1/8'') Or....Turbulence from objects protruding from hull bottom that are making a bubble trail. Just guessing here...
04-13-2018, 12:42 PM #11
04-14-2018, 02:17 PM #126000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,529
- 431
- 64
- 434
- 452
04-14-2018, 03:23 PM #13
I too would check the alignment of the engines. I've always felt that having them towed in somewhat such as 1/8 to 1/4 greater at the prop Shaft Center lines than at the nose you put tension on the steering tie bar and takes any slack and chatter out of it.
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
04-14-2018, 09:20 PM #14
04-15-2018, 11:30 AM #15
bad / soft upper and lower mounts.. dont matter if new or not, they can go bad so fast.
first time the motor is put under pressure the rubber can move inside its mount, plus they sometimes use soft crap for
smoother ride on the boat.. to me its crazy that rubber is still used. poly bushes would be much better, or solids.
Mini Speed Boats, Long or Short Shaft Motors?
By rustymarine929 in forum General Boating DiscussionReplies: 2Last Post: 12-29-2014, 01:13 PM -
what speed should I expect from 12' baja with various size motors
By john rowley in forum Props, Setup, and RiggingReplies: 2Last Post: 08-11-2008, 05:58 AM -
Crackhead, shaking from withdrawl
By pyro in forum The Scream And Fly LoungeReplies: 4Last Post: 05-20-2004, 12:22 PM -
shaking mota
By merc326 in forum Technical DiscussionReplies: 0Last Post: 05-13-2004, 02:19 PM
